Leaking Convertible
Old Oct 6, 2008 | 02:44 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Leaking Convertible
I have checked the adjustments on my top and can find nothing wrong yet on the passengers side it leaks. Anyone got an ideas?
Old Oct 6, 2008 | 03:15 PM
GreenDream's Avatar
GreenDream
I just went through this on the drivers side. No matter how much I adjusted the window in or out, it just did not put enough pressure on the top weather strip to seal it. If the top edge of your window shows, it will leak. I tried every adjustment in the book and finally realized comparing to the passenger side that did not leak, that the weatherstrip had just lost enough of its form that it was never going to seal. I used the Bubba approach and inserted a wooden dowel about 6 inches long up into the WS folds that pushed it out enough to seal over the top edge of the window. No more leaks. I used a permant marker and painted the dowel black and you cannot even see it, but it works.
If it was torn or badly worn, I would have replaced it, but looks fine and those things cost a fortune. I also went a step further on the back edge of the window and inserted a larger dowel and drastically reduced my wind noise at speed. This one is totally engulfed in the WS and you cannot see it.
My .02
Old Oct 7, 2008 | 06:31 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Can you show any pics of what you did? This sounds very interesting! I had taken my vert to a local body shop to have them adjust the windows to stop the leaks. They worked on it for two days. They called Chevrolet, and was told that it is normal for a vert to leak. have the owner carry a towel! So, I have carried a small black towel with me ever since, not knowing it can be fixed...
Old Oct 7, 2008 | 08:42 AM
homewrecker's Avatar
homewrecker
yes, pics please....us vert guys/gals gotta stick together!
Old Oct 7, 2008 | 08:48 AM
ragtop00's Avatar
ragtop00
Roger that!...
Old Oct 7, 2008 | 01:32 PM
87bob's Avatar
87bob
As far as the body shop calling Chevrolet I'll bet they called a dealer and that would make it I cannot believe that Chevrolet would say that leaking is normal. It may be a common problem but I can't believe that it is normal. A dealer just told a friend of mine that a replacement CPM for his car would be 1800.00 if they could find one. He did for less than 200.00. Dealers as a general rule don't know squat.
Old Oct 7, 2008 | 01:36 PM
87bob's Avatar
87bob
My .02
Thanks for the information pictures would be handy if you can post them.
Old Oct 7, 2008 | 01:42 PM
GreenDream's Avatar
GreenDream
Okay guys.. If it ever stops raining here, I will get out and take some pics to show you what I did. And even though it has been raining for several days, I still don't have anymore leaks..!
Old Oct 7, 2008 | 02:18 PM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
You've really got to come through with some pics and the dimensions of the dowel used. I've taken my car to stealership twice. Each time they say they adjusted the top and I will not have any more leaks. You know, my top never leaked again.....until it rained again, same leak, same place.
Old Oct 7, 2008 | 02:49 PM
ragtop00's Avatar
ragtop00
If this "mod" fixes my leaks I will have a new found respect for "Bubba repairs"
Old Oct 7, 2008 | 02:59 PM
GreenDream's Avatar
GreenDream
Nothing is more disheartening than to open your door and find your nice leather seats wet. I will get some pics soon and give you dimensions of the dowels I used. Nice thing is, you don't have to glue them or tape them in. they just stay put in the folds of the WS and expand it to make better contact with the glass. And after I stopped the leaks, It ocurred to me that maybe others over time had lost their shape. I was constantly irritated by the cabin sound of rushing air like I had my windows down. At 70 mph I reached back and pressed the seal at the rear of my drivers window out with just one finger and the noise stopped. I inserted a dowel in that to expand it and all is quiet now.
As you probably know, there is adjustment screws at the bottom of the doors to move the windows in and out. I tried several times, but found there is just too much slop in the window to take that up. I think that over time these weather strips lose their form as the window slams against them.
Pics to follow..
Old Oct 7, 2008 | 03:14 PM
87bob's Avatar
87bob
Pics to follow..
Nothing better than Bubba Engineering when done right. That's the problem with GM today it took an owner to find a solution. What was the diameter of the dowels? I wonder if a piece of vacuum hose might work the same way?
Old Oct 7, 2008 | 04:56 PM
GreenDream's Avatar
GreenDream
Good idea. I would think that vacuum hose would also work. I will get the diameter and lengths of the dowels I used and post with pics.
Old Oct 7, 2008 | 05:46 PM
ToplessBlonde's Avatar
ToplessBlonde
Eckler's sells replacement weatherstrip.
Mine leaks on the driver side where the A-pillar, roof and window all meet. I just "plumped" up the weatherstrip with a shot of silicone.
Old Oct 7, 2008 | 08:09 PM
dobewillie's Avatar
dobewillie
good ideas guys
Old Oct 7, 2008 | 08:18 PM
oakvillec5's Avatar
oakvillec5
I am looking forward to seeing the pictures, sounds like an easy fix to a problem that has existed for me for quite some time.
Old Oct 8, 2008 | 06:30 AM
hayman's Avatar
hayman
If I don't get the cover on mine before it rains then I will have a puddle behind the drivers seat. I can not seem to find the leak that is causing it. I have used the cut up credit card method and the bending of the metal support frame, still leaks.
To Leaking Convertible
Old Oct 8, 2008 | 07:15 AM
Mad Dog Peter's Avatar
Mad Dog Peter
I have the EXACT same issue on my 99 vert! EXACT same issue! Let's see some pics! And we can all fix our leaks and whistling windows!
Old Oct 8, 2008 | 07:16 AM
homewrecker
Got a steak dinner with your name on it buddy
Old Oct 8, 2008 | 09:24 AM
Yoggi's Avatar
Yoggi
Interesting!
