[Z06] top speeds?
Old Oct 14, 2008 | 08:53 PM
Mr Maui Wowi's Avatar
Mr Maui Wowi
Default top speeds?
hi just sold my c6 z about a month ago and was gonna get a c5 z06...more mods with the same or less money. i was just wondering who's been brave enough to open pandora's box and how fast did you get?
Old Oct 14, 2008 | 09:26 PM
HWY HNTR's Avatar
HWY HNTR
18X in mexico lol.
I was on 21psi on nitto dr's. dumb move...
Old Oct 15, 2008 | 01:36 AM
slowblack00's Avatar
slowblack00
maxed the speedo out, dunno, 200+
this vid was the closest i got to catching it, she caught me as i was coming down from it
http://www.youtube.com/watch?v=QI3DO0V-s24
Old Oct 15, 2008 | 07:22 AM
SJSZ06's Avatar
SJSZ06
IB4TL... holy ****! looked like he was standing still.
Old Oct 15, 2008 | 07:42 AM
Jeffyvette's Avatar
Jeffyvette
Default need accuracy
Don't believe your speedo. Mine checked against GPS is 10 mph fast at 175mph. So get a GPS to see the real numbers. I will remember it for you so you can keep your eyes on the road. A closed road or course of course, never on a open road.
Jeffy'
Old Oct 15, 2008 | 07:54 AM
Ryan L's Avatar
Ryan L
The C5Z is geared aggressively, so it redlines 5th gear at a lower RPM than less powerful cars like the base model C5. 6th gear is OD, so you won't accelerate much unless you add alot more power (like an LS7.)
Old Oct 15, 2008 | 12:12 PM
79inSD's Avatar
79inSD
In a open road race I was radared at 163. My speedo reads slow, and I took here up to my max speed allowed of 168. I have no mods and I am guessing by the rpm I would have made it to about 175ish.
Old Oct 15, 2008 | 01:26 PM
HWY HNTR's Avatar
HWY HNTR
I assume that vid was in mexico. no US laws were broken.
Old Oct 15, 2008 | 01:37 PM
slowblack00
absolutely, you know from texas its not that far a drive to mexico, we take trips often
as for my gearing, i took out the mn12 and put a fully built mn6 in there, the ratio was a bit better for my setup.
-j
Old Oct 15, 2008 | 01:41 PM
Bigstik's Avatar
Bigstik
I have only had mine up to the 155 mark....what a rush.....in mexico of course.
I certainly hope you topped your washer fluid off...
Old Oct 15, 2008 | 03:26 PM
darbn's Avatar
darbn
I got up to 137ish messing around with an Lexus ISF. I was in Mexico...
Old Oct 15, 2008 | 03:37 PM
FasterIsBetter's Avatar
FasterIsBetter
They say that the C5s are aerodynamically limited to around 178 mph with stock HP. That's in 5th gear, because there is not enough HP to overcome wind resistance/drag with the gear ratio in 6th. Now, if you add significantly more HP, could you pull 6th gear? Maybe.
Now, would you want to go that fast? Not me. I've hit between 155 and 160 on the back straight at Pocono Raceway a couple of times. Things happen pretty quickly when you are moving that fast. I certainly would never want to go anywhere near that fast on the highway, it's just too dangerous. And the only way I would want to go faster would be someplace like the Bonneville salt flats or on one of those super-long airport runways where they do speed tests, where there is a lot of room for error and no one around to accidently pull in front of you and no pot holes, etc.
Old Oct 15, 2008 | 05:11 PM
slowblack00
mexico has nice 6 lane wide highways. all straight with no cars in sight at 3 am, not a bad deal.
ill be competing at the next texas mile too, hope i can grab 200+ in a mile, ill get a plaque!! WOOt
my engine builders promise my car will hit 200+ in the mile, so im looking foward toit
Old Oct 15, 2008 | 11:05 PM
RaleighSS's Avatar
RaleighSS
Default Maxton Run
I ran 159.2 at the maxton mile... Standing mile run on a shorty tube header car at the time. Video is below ... you can see at the end I blip the throttle to keep it under 160... So I think without the granny shifts more aggressive starts or blip she may have done 163-4 in the mile.... but the sped def was slower to come past 150.
http://www.youtube.com/watch?v=OQygZGSeaGc
Old Oct 16, 2008 | 05:45 PM
acothern's Avatar
acothern
St. Jude Donor '08-'10
I hit 172 in 5th gear at 6500 RPM on the German Auto Bahn. That was with wife and a couple of hundred pounds of luggage. I got a picture of speedo at 162 but didn't get the 172 on film...
Old Oct 16, 2008 | 10:39 PM
PRE-Z06's Avatar
PRE-Z06
I did 187mph w/ 380rwhp before gears and heads (basically the same aerodynamics and power as a bolt-on Z)
Old Oct 16, 2008 | 10:49 PM
Z06Liter's Avatar
Z06Liter
Top of 5th is 174 in this video
http://www.youtube.com/watch?v=qc4RaezWbkU
To top speeds?
Old Oct 16, 2008 | 11:05 PM
PhatZO6's Avatar
PhatZO6
Speedo said 177 mph and HUD displayed 174..GPS read 175.......All I know is that it was a RUSH>>>>>>>
Old Oct 17, 2008 | 02:16 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default I love the tacos in Mexico!!
GM claims 171 mph on a C5 Zo6.
I've hit/bumped the rev limiter in 5th gear with the speedo showing 177 in my '01.
I know that my reading is a little fast, because when I turn my cruise control on at an indicated 70 mph, the read out on the display says "cruise set 72 mph."
So I'm guessing with that ratio and the speed in 5th gear, the GM claim of 171 is about right..
I didn't try to continue in 6th
Old Oct 17, 2008 | 06:11 AM
David426's Avatar
David426
Car and Driver magazine ran 168 mph at the redline 6500 rpm in 5th gear on a 2002 z06. I'd say maybe 172mph if you want to bounce off the rev limiter at 6700 rpm
