What are your year-end projects?
Old Oct 26, 2008 | 01:48 AM
  #41
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Since you didnt specify "automotive" projects I'll assume ANY project...My 24x20 carport for our Daily Drivers BETTER be done by the end of next month...Hopefuly there wont be any more delays...The concrete slab and piers were finally poured last week...Actual construction is "supposed" to start Monday....but then again the entire project should have been finished by now
Old Oct 26, 2008 | 01:55 AM
  #42
The NNIAL8R
Originally Posted by Kale
NICE!!!!....Here's the set-up I installed in my 99 Coupe...two 8 inch square Kicker Solo-Barics...1500 watt MTX amp...it KICKS!!!!...It even got magazine coverage!!!
Old Oct 26, 2008 | 03:01 AM
  #43
tsts's Avatar
tsts
Insulation, complete car.
Old Oct 26, 2008 | 12:24 PM
  #44
2000lambovette's Avatar
2000lambovette
For the vette I want a lot but may only be able to afford a couple.
1. PFADT coil overs and components.
2. Double din stereo/dvd.
3. Heads/ cam would love to get sts turbo but dont want to spend $7000
4. New Style wheels if I can find another set of 18x12 that I like.
5. If L5 comes out with front flares then that too.
6. New seats hopefully Caravaggio
Old Nov 12, 2008 | 11:15 PM
  #45
brian vette's Avatar
brian vette
Default Project
Here is mine
http://forums.corvetteforum.com/c5-g...ell-build.html
Old Nov 13, 2008 | 12:50 AM
  #46
Mr. Lau's Avatar
Mr. Lau
Does passing 1st semester with 90+avg count?
Old Nov 13, 2008 | 01:18 AM
  #47
hawaiiC5's Avatar
hawaiiC5
St. Jude Donor '09
i hope to get headers before the year ends.
Old Nov 13, 2008 | 08:44 AM
  #48
Gideon's_Test's Avatar
Gideon's_Test
Before spring, I hope to:
-Install my long tubes
-Get a tune
-Replace the neo wedge bulbs in my DIC controls
-Install my active cross-over sound system (probably not going to happen, as I don't have everything I need for this yet)..
-Pull and fix rocking seat
Old Nov 13, 2008 | 09:12 AM
  #49
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
reguarding the neo wedge bulbs, I stronglyy reccomend you remove the bulbs from the holders and solder them into place. Mine kept slipping out and it drove me nuts. I ended up taking apart my dash 4 times before i finally just whipped out the solder gun.
-Get a tune
Old Nov 13, 2008 | 09:17 AM
  #50
Gideon's_Test
TheRadioFlyer: Thanks for the tip regarding the holders. Soldering sounds like a good plan. I'd love to use LED's, but don't feel like fooling around with the polarity issue, unless there is a non-polarized verion available....
Old Nov 13, 2008 | 09:23 AM
  #51
Twospeed's Avatar
Twospeed
Will not be done by Jan 09 but I don't really care. I'm on my way no turning back now.
Finish modifying and installing my Depo Lights
Install HIDs into fogs
Re wire My C5-r running lights
Under drive pulley
Cam install (Custom grind)
Fabricate my own Cat delete
Re-locate coils
04’ PVC system
Repair front speakers (I have a 1000 w system)
Re-tune
Make up my mind either Street warrior or fast
There you have it! An 11 sec car that can see in the dark.
Old Nov 13, 2008 | 10:05 AM
  #52
MisterTwister's Avatar
MisterTwister
Be alive January 1 2009
Old Nov 13, 2008 | 10:14 AM
  #53
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Polarity is easy to figure out. Leave the unit plugged in, and turn on the illumation with the bulbs out. place the bulb in the socket backwards (bulb facing you) and note the position of the electrodes. turn the bulb around keeping the electrode contacts in the same positon and solder.
Twospeed: Good to see another light guy. What are you re-wiring about the running lights?
Old Nov 13, 2008 | 10:46 AM
  #54
chris holmes's Avatar
chris holmes
Going up to ECS next week for the following;
ECS radiator package with oil cooler,
minitub,
ECS front brake ducts,
Tial 50 BOV,
ECS power steering kit
Old Nov 13, 2008 | 12:23 PM
  #55
tbrent's Avatar
tbrent
2018 C5 of Year Winner
To get you to Georgify my Z....
Hopefully a Sequential Halo mod Still waiting on word for my flux capacitor...
Sell my Iforged Daytona's and find some wheels to fill the L-5's.
Maybe find some LT's.
Just did the JDM Audi R8 lighting mod. Need to go through the interior lighting with more leds and send hvac to Tim.
Maybe a FI setup.
"Go by Home Depot---Yeah, buy some wallpaper... Maybe get some flooring. Stuff like that, maybe Bed Bath & Beyond. I dunno-I don't know if I'll have enough TIME."
Old Nov 13, 2008 | 02:44 PM
  #56
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Meth kit for sure...
To do a tour up and down the Central/Eastern US states and meet some Corvette buddies !
Old Nov 13, 2008 | 02:51 PM
  #57
Tigershark3's Avatar
Tigershark3
Mine are pretty modest compared to some of these but it'll be Bilstiens, C6Z06 shifter and maybe HIDS.
To What are your year-end projects?
Old Nov 13, 2008 | 04:11 PM
  #58
tbrent's Avatar
tbrent
Come on through Bubba!
Old Nov 13, 2008 | 04:27 PM
  #59
4 KRUSIN's Avatar
4 KRUSIN
Double din bezel and new audio system w/nav.
Old Nov 13, 2008 | 04:53 PM
  #60
4U2ENVY's Avatar
4U2ENVY
From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
Paint calipers
c-5 hood decal
c-5 letter front
c-5 letter rear
carbon fiber wheel well covers
ghl catback bullits
lloyds floor mats
master cylinder cover
throttle body id plate
power brake booster
power steering cover
fuse panel cover
headlight covers
chrome engine caps
door sill w/o ribs
trunk liner
door sill w/o ribs (inner)
alternator cover
c-5 polished plenum
belt tension cover
chrome dip stick
battery den cover
air coupler
hood struts
decelarotors
fuel rail letter kit
paint the following
coolant reservior
washer reservoir
painted fuel rails
painted radiator cover
and much more to come.
