speedo vs gps
Old Oct 24, 2008 | 11:08 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by Mike Mercury
not quite.
GPS is an approximation. The speedo is a direct measurement; and that's as accurate as it gets.
(this is assuming there isn't a failure somewhere in the OP's speedometer system)
Mine both read the same, But I agree with the above, Too many variables in the GPS.
Old Oct 24, 2008 | 11:28 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
GPS gets my vote everyday
Old Oct 24, 2008 | 11:36 AM
steve8's Avatar
steve8
No great answer here, but why not start with a measured mile and see what your odometer says, then check that vs. time.
10% is a lot for anything to be off.
Old Oct 24, 2008 | 03:09 PM
SilverBullit02's Avatar
SilverBullit02
One more thing to consider here......GPS uses a satalite signal to calculate your speed from point "A" to point "B". It also calcultes speed from "A" to a nonspecified point. BUT it is all calculated "As the crow flies" A to B may be 10 miles apart as the crow flies (straight line) but may be 15 miles apart by the exixting road. The speedo reads how fast your covering the asphalt, the GPS reads how fast you are getting closer to "B", leaving "A" etc.
Old Oct 24, 2008 | 03:21 PM
germanc5's Avatar
germanc5
just a couple of points.
i have compared gps to the suburban-dead on
my v-max is off.
when in the vette all day i have compared them numerous times throughout the trip. always the same discrepency(sp?)
also, are mile markers always exactly placed?
any road commission employees here?
thanks for all the input
Old Oct 24, 2008 | 03:28 PM
Mr.Bill's Avatar
Mr.Bill
my v-max is off.
I have found that the mile markers here in Nevada are dead on. I think they would be everywhere. , Any speedo shop can calibrate your MPH for you if you are really off.
Old Oct 24, 2008 | 03:30 PM
steve8's Avatar
steve8
I don't know about the regular mile markers on the road. I would seriously doubt they are exact.
I meant areas that have measured mile starts here, and then there is an end sign.
Old Oct 24, 2008 | 03:59 PM
Mike Mercury's Avatar
Mike Mercury
if two trains... leaving in opposite directions...
http://forums.corvetteforum.com/show....php?t=2166177
Old Oct 24, 2008 | 04:03 PM
oakvillec5's Avatar
oakvillec5
my speedo matches the GPS
Old Oct 24, 2008 | 04:13 PM
2KFRC5's Avatar
2KFRC5
My GPS gives real-time speed. Straights or curves, matches the speedo. No point A to Point B even programmed. Point A to Point B now depends on how fast your GPS refreshes.
Old Oct 24, 2008 | 05:02 PM
PONI ETR's Avatar
PONI ETR
I'm not so sure about that. The V Box calculates 0-60 and 1/4 mile times by pinging the satellite 10 times/sec. I believe it uses triangulation to calculate speed and time, and at 10/sec., I don't think it's calculating as the crow flies.
But I got my degree in backyard physics at the College of Small Minds.
Old Oct 24, 2008 | 06:46 PM
DefenderC5's Avatar
DefenderC5
That's not really how it works, it updates very quickly. GPS is very accurate, most civilian receivers can track more satellites (making it more accurate) than most of the military equipment I have used. Even our stuff was good to less than 1 meter when tracking the max amount of sats, the garmin type stuff is currently no different (if not better)... it is the same signal regardless of the receiver you use.
Speedos are generally accurate, but can vary from vehicle to vehicle due to mechanical difference... motorcycles are certainly a good example of this. My bike reads 167 mph when the GPS only reads 150 mph. Given I still had a couple hundred RPM to go in 6th gear and it is mechanically limited to 155 mph, it's only logical the GPS was correct. Granted, the error increases the faster it goes.
Now if your GPS receiver is only tracking 3 satellites at a diminished signal (weather, mountains, tall buildings etc), yes your accuracy will decrease.
As far as the OP goes, 10% is quite a bit... I'd get the speedo/settings checked and trust what the GPS is displaying.
Old Oct 24, 2008 | 07:48 PM
  #33
Mike Mercury
this is true; and any GPS made in the past 5 years or so has a fast aquisition repeat rate.
But I can't help to further remind people that a GPS measuring speed ...is based on a calculation; and nothing beats actual on-the-ground direct measurement.
Granted, the two may be so close to each other that it's not worth haggling over... but the GPS "guesses" and can't be used as a standard or end-all measurement device.
Old Oct 24, 2008 | 09:05 PM
  #34
fdxpilot's Avatar
fdxpilot
But then, again, all the speedometer does is measure revolutions of the differential output shaft. Everything on the speedo and DIC is a calculation from that figure, based on tire diameter and basic geometry. It is no more accurate than the GPS saying you were there then, and here now, so you are going this fast.
Old Oct 24, 2008 | 09:15 PM
  #35
65GGvert's Avatar
65GGvert
The GPS is not an approximation, it is a measured distance change in a designated amount of time, converted to mph. It is not subject to the variables of tire size, tire wear, etc. I'll go with the GPS every time. By the way, mine matches all three cars within 1 mph. If something is off 10%, it's not the GPS.
Old Oct 25, 2008 | 01:37 AM
  #36
lionelhutz's Avatar
lionelhutz
My speedo measure fast compared to the GPS. But, my DIC cruise setting measures right on. If I set it to 60mph or 70mph or 80mph the GPS says that is the speed within about 1/2 mph. But, my speedo itself is still reading higher a little bit.
Really? And the C5 doesn't do a calculation based on the number of times the differential rotates per unit of time??? How is that calculation any better. Besides, the GPS units sold today will have about 12 or 13 years newer computing technology compared to the C5.
Peter
Old Oct 25, 2008 | 12:28 PM
  #37
Rich-L's Avatar
Rich-L
My 04 vert speedo and Garmin GPS read the same.
To speedo vs gps
Old Oct 26, 2008 | 04:12 PM
  #38
germanc5's Avatar
germanc5
is that like my GED in construction?
( Good Enough Dude)
Old Oct 26, 2008 | 05:28 PM
  #39
vette dan's Avatar
vette dan
Vette Dan
And I hate to disagree with Mike but a GPS is very accurate. We use them to fly bombs in windows.
Old Oct 26, 2008 | 05:30 PM
  #40
moserbe's Avatar
moserbe
Originally Posted by c5 BearsFan
my gps and speedo always read the same.
Mine read the same also.
