speedo vs gps
Old Oct 23, 2008 | 06:30 PM
germanc5's Avatar
germanc5
Default speedo vs gps
my speedo is approx. 10% faster than my gps. which is right? if it is the vette then i have 6800 more miles on my odo than on the car. (and thats not fair). how to recalibrate?
also keep in mind that this is an export car. 300kph speedo
Old Oct 23, 2008 | 06:34 PM
PONI ETR's Avatar
PONI ETR
If everything is stock, I'd vote for your speedo as correct.
If they have those roadside radar speed displays in your area, compare with that.
Or look for a speedo shop to check it.
Old Oct 23, 2008 | 06:41 PM
germanc5's Avatar
germanc5
the car is stock exc. for the exhaust.
also gps agrees with my suburban but disagrees with my v-max. although bikes are notorious for inaccurate speedos.
my wife says she has compared to radar and claims its the speedo at fault.
speedo shop or stealership?
Old Oct 23, 2008 | 07:04 PM
65GGvert's Avatar
65GGvert
The GPS is correct.
Old Oct 23, 2008 | 07:15 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
my gps and speedo always read the same.
Old Oct 23, 2008 | 07:21 PM
germanc5's Avatar
germanc5
unless it has something to do with being an export, i don't know why it should be off.
is there a tuner or programmer that can calibrate the speedo? this would kill 2 birds.
Old Oct 23, 2008 | 07:37 PM
2KFRC5's Avatar
2KFRC5
Same here.
Non-stock size tires can cause speedo error. But, 10% is a lot.
Old Oct 23, 2008 | 08:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
The speedo in both Vettes and our Silverado are within 1 mph of my Garmin so your speedo must be off
Old Oct 23, 2008 | 08:44 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
OK,
Here's the deal. The only way to 100% acurately gage your speedo is to have a dyno tune. No miscalculation there. Another close way is to put it in cruise control and time yourself between known distances, such as mile markers on a highway. The greater the distance, the better.
GPS is pretty accurate. However, it is only accurate in certain circumstances. The road has to be flat, with little to no elevation changes.
All else equal, I'd wager that the GPS is more accurate.
I had a similar problem with my TransAm. Someone messed with the calibration during gear changes, but did it wrong. Later, after another gear swap, I found out that it was still off. Speed calculators, the infamous 75mph in 3rd gear trick, etc are all inaccurate. Little things like tire pressure and tread wear also contribute to your speedo being a couple percent off.
I used a combination of methods, and the GPS, being paced, measured distances all agree'd that my speedometer was off.
I ended up correcting it with a Diablosport, and then later refining it more with HPTuners.
The ONLY thing that should affect your speedometer in a vette is the tire size. Replace them lately?
Old Oct 23, 2008 | 08:45 PM
coveett's Avatar
coveett
You can check your speedometer accuracy with a stopwatch and a straight uncrowded Interstate Highway with mile markers. Set your cruise on 60 mile per hour. Clock your time between several sets of mile markers. If it averages out to 60 seconds between each set of mile markers then your speedometer is accurate at 60 mph. Speed = distance x time. 60 mph is one mile a minute.
Old Oct 23, 2008 | 10:29 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Old Oct 23, 2008 | 10:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
My Vette and GPS read the same.
Old Oct 23, 2008 | 10:45 PM
atsugidad's Avatar
atsugidad
Before Changing C5 Coupe tires to Z06 Sizes (295/35/18) my GPS and speedo were EXACTLY same.
After tire swap the speedo was 2 MPH faster.
Recal'd tire sizes with Predator and they are EXACTLY same again.
Old Oct 23, 2008 | 10:49 PM
ValiantSailor's Avatar
ValiantSailor
Originally Posted by 65GGvert
The GPS is correct.
I wouldn't bet my license on that. The GPS system is sending a radio signal which is then averaged in a computer chip in your unit. It will always lag in some degree, your actual speed. You might want to do a software download to your GPS or find out if there are any updates for it that aren't installed.
Old Oct 23, 2008 | 11:23 PM
4 KRUSIN's Avatar
4 KRUSIN
I have the 300 mph speedo and it reads the same as the GPS.
Old Oct 23, 2008 | 11:57 PM
Whiteonrice's Avatar
Whiteonrice
I would have to go with the GPS. On a flat surface it is very accurate.
Rick
Old Oct 24, 2008 | 12:22 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
The GPS is correct.
Just a FYI, you cannot fix it via a Tech 2.
Im waiting til I buy HPTuners to fix mine myself!
To speedo vs gps
Old Oct 24, 2008 | 12:23 AM
versatile's Avatar
versatile
Gps!
Old Oct 24, 2008 | 10:10 AM
Mike Mercury's Avatar
Mike Mercury
The GPS is correct.
not quite.
GPS is an approximation. The speedo is a direct measurement; and that's as accurate as it gets.
(this is assuming there isn't a failure somewhere in the OP's speedometer system)
Old Oct 24, 2008 | 10:56 AM
Dominic Toretto's Avatar
Dominic Toretto
Subscribed.
-Alex
