speedo vs gps
Old Oct 26, 2008 | 05:52 PM
  #41
PuddleJumper's Avatar
PuddleJumper
I would test out your GPS for accuracy if you can get it out of the car,
and maybe if you can go bug an cop buddy (Ie if you have one) to use his laser pointer speed thing to see if the speedo is off or maybe those roadside speed things
or have an friend drive at an set speed an fallow them and see what you come up with
some ideas anyway
Old Oct 26, 2008 | 08:51 PM
  #42
RonJ's Avatar
RonJ
Checked mine to-day.
With the cruise locked at 105kph, the GPS read the same, 105kph, the odd time dipping to 104kph and then back to 105.
RonJ ...
Old Oct 26, 2008 | 11:55 PM
  #43
Mike Mercury's Avatar
Mike Mercury
I should of said "approximation" instead of calculation.
Old Oct 27, 2008 | 12:02 AM
  #44
Texas Dave's Avatar
Texas Dave
I'd vote for the gps being correct.
My dash is like .5mph over the gps or something. sometimes its exact, sometimes not. And my hud always seems to show 1mph faster than my cruise is set. weird.
Old Oct 27, 2008 | 12:08 AM
  #45
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
My Alpine Blackbird has a speedo function on it that always reads about 5-10mph slower than my speedo.
The GPS updates my position about 3-5 times per second but the car's speedo is constantly being updated. I would venture to guess the GPS systems in our cars simply aren't fast enough to update with super-accurate real-time speed.
Old Oct 27, 2008 | 12:16 AM
  #46
Texas Dave's Avatar
Texas Dave
I'm using a garmin unit to compare mine. And with the cruise set, even a slow gps could still read the speed.
Old Oct 27, 2008 | 08:44 PM
  #47
65GGvert's Avatar
65GGvert
I repeat, the gps is correct. To the original poster, please post here what you find when you get everything checked out. Don't leave everyone hanging.
Old Oct 29, 2008 | 07:48 PM
  #48
germanc5's Avatar
germanc5
i can't say when i'll take action on this. apparently it has been put in line behind powdercoating the wagon wheels black. but when i fix it i'll update.
thanks again for all the responses
maybe someone in the mooresville, nc area will take me and my gps for a spin in their vette and compare the two gps's. pm me for the spin
Old Oct 29, 2008 | 09:43 PM
  #49
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
my tom tom and magellan measure the same, as well as on two cars I have tested.
my money in the long haul is on your gps.
Old Oct 29, 2008 | 10:05 PM
  #50
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Originally Posted by Mike Mercury
But I can't help to further remind people that a GPS measuring speed ...is based on a calculation.
So is the C5 speedometer.
It's a calculation of speed based off read wheel speed sensor pulses, coupled with (programmable) tire height data.
I've compared both my truck and C5 to GPS, and both are right-on...but if there were a case of substantial difference between the two, I would lean toward GPS as being the more accurate indicator.
There's been many more than one known case of odd values showing up in a stock PCM tune.
Old Oct 29, 2008 | 10:33 PM
  #51
jlbruggeman's Avatar
jlbruggeman
If there is a 10% difference, the car is off most, if not all of the 10%, the GPS will be real close!
