Weight reduction:
Old Nov 20, 2008 | 11:05 PM
SILVER ZO6's Avatar
SILVER ZO6
Default Weight reduction:
Necessary to take out passenger seat out and drain out washerfluid.
To gain more ''Speed and Sec'' at the track. Your only taken out about 35punds is it worth it.
Old Nov 20, 2008 | 11:16 PM
OK. Obviously the more things you take off the car, the lighter it will be and should result in a faster time.
Old Nov 20, 2008 | 11:30 PM
poolboy's Avatar
poolboy
This thread has lots of info on wieghts - you can find other things to remove...
Old Nov 20, 2008 | 11:39 PM
SILVER ZO6's Avatar
SILVER ZO6
Thanks'
Old Nov 20, 2008 | 11:55 PM
dobewillie's Avatar
dobewillie
no double cheeseburgers for you
Old Nov 21, 2008 | 08:30 AM
bucwheat's Avatar
bucwheat
Drop the spare!
Old Nov 21, 2008 | 08:43 AM
johninar's Avatar
johninar
Originally Posted by bucwheat
Drop the spare!
As soon as I find it, it's outta there.
Old Nov 21, 2008 | 08:49 AM
Oldvetter's Avatar
Oldvetter
Here are the weight reduction specifics:
Weight reduction
You can achieve substantial weight reduction with the following modifications, while still having a car that's very comfortable to drive. Most of these modifications will directly increase (and decrease in a few cases) the safety of the car, while safety is indirectly improved due to the better handling and limits of a lighter car. Fighter pilots say "speed is life". Acceleration, deceleration, and lateral acceleration are all forms of acceleration, and lighter cars accelerate better in each of these ways because the tires have less mass to control....thus a lighter car is a safer car. Lighter cars have better moments of inertia which allows them to turn in more easily and roll less. Lighter cars are also easier on the tires and gas.
All the stage weight estimates are typically wild butt guesses, but it makes it easy to see what is possible. The weight listings in the separate weight posting is MUCH more reliable.
Stage I: Streetable weight reduction mods
Non-popup headlights (~40 lbs)
Braking rotors with an aluminum hat, or titanium rotors (unproven on street cars) (~20-30 lbs)
Carbon fiber hood (~12 lbs)
Z06 (thinner) windshield and side windows (~5.7 lbs)
Non runflat tires (~20 lbs)
Slicks (~30 lbs)
Z06 wheels (~4 lbs est.)
Corsa titanium exhaust (~35 lbs)
Long tube headers (~20 lbs)
Halltech aluminum alternator & bracket (10 lbs)
Carbon fiber driveshaft (~2 lbs)
Newer torque tube
Less options [HUD, elec AC, Active Stability, seat/mirror/steering wheel memory, cd changer] (~50 lbs)
Less gasoline & wiper fluid (No wiper fluid=9lbs, 6 lbs for every gallon of gas in that 18 gallon tank....~81 lbs for autocrossing)
Remove
cargo net
targa top (~20 lbs)
BCM’s
C5 "appearance mods" - exhaust plates, doorsill covers, etc.
fuel rail covers
all loose change, CD's, golf clubs, misc. items, from center console, hatch area, and glove box
Replace
stock crank pulley with aluminum aftermarket pulley
steel dampener with aluminum dampener
stock targa top with lexan piece (coupes)
water pump with electric water pump
battery with smaller battery
non-stressed fasteners with aluminum or titanium fasteners
leaf springs with coil over shocks with titanium springs
steel shifter with aluminum shifter and delrin or titanium shift ****
Empty your pockets of extra change, PDA's, cell phones, keys, lead plates, or whatever other junk you lug around
Go on a diet =p
Stage II: Hardcore semi-streetable weight reduction mods
Aluminum flywheel (~10 lbs)
Lighter clutch like Exedy or Quartermaster (~10 lbs)
Racing buckets (40-50 lbs)
Off-road x-pipe (10 lbs)
Replace stock hood, fenders, doors, roof, hatch and bumpers with aftermarket carbon fiber pieces
Remove
Tire repair kit (Z06)
Floor mats
Fog lights
Stage III: Track only weight reduction mods
Racing steering wheel & delete both airbags (~30 lbs, but get a 4-6 point harness)
Use unpadded aluminum or carbon fiber steering wheel
Run open headers
Replace stock front and rear glass with polycarbonate “glass”
Rebuild motor with Al or Ti connecting rods, Ti valve spring retainers and pushrods
Port the heads
Replace valve covers with magnesium or carbon fiber parts
Strip entire car, acid wash chassis, put car back together.
Remore
Column locking hardware
Interior – passenger seat, carpets, speaker panels, head liner, dash, center console, glove box, door panels, sun visors, rear view mirror, insulation, etc.
A/C Compressor
A/C controls and ducting
AIR pump system
Factory radio, speakers, and/or CD changer, and unnecessary wiring
HUD projector
Windshield wiper fluid reservoir and pump
Windshield wipers and motors
Stock cat back
Power steering pump
Front sway bar (drag only)
ABS, TC, AH hardware and sensors (drag only)
Fender wells
Headlight assembly, turn signals, taillights and reflectors
Shave side mirrors
Torque tunnel cover
OEM seat belts
Parking brake
Side windows and motors
Power locks and power windows
Side impact beams
Casting flash from engine, then polish
Reducing unsprung weight—not all is streetable
Forged 1-piece wheels
Use 3-piece wheels by Jongbloed, Kodiak, CCW, BBS
Skinny front wheels (drag only)
Ti fasteners on 3-piece wheels (~1 lbs per wheel)
Lighter non-runflat tires, or even track only synthetic corded slicks
Lighter calipers
2-piece, unvented or titanium rotors
Titanium wheel studs
Aluminum or titanium lug nuts
Remove tire pressure sensors
Remove rubber valve stem cap
Balance the wheels without tires or balancing weights, and then mount tires
Old Nov 21, 2008 | 01:55 PM
corvettebob1's Avatar
corvettebob1
Lot's of Ultra Slimfast.
Honestly that was told to a friend of mine while he was buying a fiberglass bumper for his GN.
Old Nov 21, 2008 | 02:19 PM
Bill Dearborn's Avatar
Bill Dearborn
Also drill lightening holes in all brackets and hinges.
Bill
Old Nov 21, 2008 | 03:13 PM
AU N EGL's Avatar
AU N EGL
Carbon Fiber Hood,
Carbon Fiber body parts
Carbon Fiber drive shaft
PLUS
add Roll cage wt
Add fire suppression
Removable steering wheel hub
add bigger radiator
add transmission and oil coolers
add dry sump, or at least accu-sump
remove window washer tank
remove windshild wipers and motor
remove HVAC components and replace with two computer fans for window
remove hinges for hood. use hood pins
remove fuel tank and replace with fuel cell
Replace all hoses with braided steel hoses.
ie about 2600 lbs at best more like 2850 lbs all said and done
Ok
Titanium wheel studs - must use steel ARP or GM racing studs
Aluminum or titanium lug nuts - must use steel open ended
Remove rubber valve stem cap - steel valve stem
Balance the wheels without tires or balancing weights, and then mount tires- who balances tires any more ? My tires move 2" on the rim for any give day on the track.
To Weight reduction:
