what do this codes mean?
Old Nov 28, 2008 | 11:11 PM
ncevette's Avatar
ncevette
Default what do this codes mean?
i posted a check engine light a few days ago and some one told me how to pull up the codes on the board and i did this is what i got
10 pcm 2-codes
10-pcm p0300h
10-pcm p1133hc
28-tcs c1276h
thanks in advance
Old Nov 28, 2008 | 11:26 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Look it up here.
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
C1276 Delivered Torque Signal CKT Malfunction
P0300 Engine Misfire Detected
H=History and C-Current code.
Old Nov 29, 2008 | 12:12 AM
ncevette's Avatar
ncevette
Originally Posted by Bill K
Look it up here.
how do i fix it car runs fine sorry new with this thanks
Old Nov 29, 2008 | 12:59 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You can ignore the History codes, but you can track them to identify a possible intermittnat problem. I personally haven't seen a History and Current code pop up...
The 1133 indicates the Front Driver's Oxygen Sensor either was out of range or is getting flaky on you. Check it's wiring and connections for looseness, damage, corrosion ect. If all seems well replace it, it's easy enough to replace so I would replace both sides...
You should completely fill out your profile, especially info on your car when asking for help.
Old Nov 29, 2008 | 01:04 AM
DeeGee's Avatar
DeeGee
Health warning; I'm no engine expert I just have the Shop Manual
The PCM monitors the HO2S sensors and sets the code when the switching cycle does not run correctly.
The diagnostic procedure is quite long but the first and simplest check is for an exhaust leak. I'd start there.
Next check is that the HO2S sensor is securely installed, check for corrosion on the sensor terminals, "terminal tension" at the sensors (whatever that is) and for damaged wiring on the circuit.
Is your engine/exhaust system stock? If not how recently did you have headers or exhaust work done?
Old Nov 29, 2008 | 10:55 AM
ncevette's Avatar
ncevette
no its stock exhaust the ho2s sensors are in the h-pipe right
Old Nov 29, 2008 | 03:30 PM
rodknock's Avatar
rodknock
2 of them behind the cats and 2 of them in front of the cats.:o
To what do this codes mean?
