Headlight problem
Old Dec 7, 2008 | 01:33 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Headlight problem
When I turn my lights off it sounds like the motor still runs for about 20 to 30 seconds. Also when I turn just the park lights on the headlights pop up. What's up with that crap? Anything major?
Thanks!
Old Dec 7, 2008 | 01:38 PM
DeeGee's Avatar
DeeGee
Your headlight motor gears are stripped. The stock gears are plastic. Most of us have replaced them with brass gears.
Run down to the headlight gears post at this link and you'll find out all you need to know
http://forums.corvetteforum.com/c5-g...ngths-etc.html
Old Dec 7, 2008 | 02:08 PM
mtndv8's Avatar
mtndv8
Thanks!
do you have HID's?
Old Dec 7, 2008 | 02:22 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Originally Posted by mtndv8
do you have HID's?
No I do not have HID's
Thanks!
Old Dec 7, 2008 | 02:23 PM
mjmc1273's Avatar
mjmc1273
Old Dec 7, 2008 | 02:28 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Thanks!
In that case, switch them over to HIDs while you're changing out your plastic gears for brass ones. Best lighting improvement you can make.
Old Dec 7, 2008 | 02:33 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Thanks DeeGee!!!
Old Dec 7, 2008 | 03:35 PM
mtndv8's Avatar
mtndv8
Thanks!
Did the problems start at the same time?? I have HID's and sometimes I get the headlights coming up when I just go to parking light, too.
Your question is one I've been wondering about since swapping to HID's.
I don't have any noticable problem with the gears, though.
No grinding or running long. Quite crisp in opening/closing.
I was just wondering if there's a correlation, as in; my motor/gear(s) are about to go out?
Good luck with the gear fix!! Can't miss with the help on this forum!
Old Dec 7, 2008 | 04:08 PM
DeeGee's Avatar
DeeGee
Thanks DeeGee!!!
Old Dec 7, 2008 | 09:35 PM
sneakelman's Avatar
sneakelman
You have a PM.
Old Dec 7, 2008 | 10:55 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I replaced one that did this and now my other one is doing this. Follow the link provided and you will be good.
To Headlight problem
