[Z06] Shifter questions
Old Dec 11, 2008 | 09:48 AM
81c3's Avatar
81c3
Default Shifter questions
I'm trying to decide on which shifter to go with for my 02 Z. Both of my choices are for used units. The first one I'm looking at is a B&M Ripper. The second one I'm considering is a C6 shifter. Since so many have already had one, I imagine the B&M is a pretty straight forward swap. The questions I have are, will the C5Z **** and factory boot work with the C6 version? Also, is there a difference between the base C6 and C6Z06 shifters?
TIA
Old Dec 11, 2008 | 09:57 AM
TEXHAWK0's Avatar
TEXHAWK0
The base of all the shifters is the same, except the Z06 shifters have metal bushings where they mount to the tunnel instead of rubber.
The C5 **** will not fit a C6.. the C5 has threads on the shaft, the C6 uses a set screw, and I think the shaft is a different diameter.
I have had a Hurst for 5 years, and of course, think it is the best.
Old Dec 11, 2008 | 10:56 AM
bullitt4110's Avatar
bullitt4110
I have had both and prefer the c6z shifter over the B&M. For the C6 shifter you need the shifter and the ball, I bought the redline goods shift boot to go with the shifter aswell.
Old Dec 11, 2008 | 11:20 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
I also have had both. I would say to go with the C6 shifter. Plus I modified my stock shift boot to work, and it is not hard to do at all. You will like how it shift.
Old Dec 11, 2008 | 01:24 PM
sublime1996525's Avatar
sublime1996525
I have the c6 shifter and I think it's a good mix between the aftermarket short throw and the standard shifter.
I modified my stock boot to fit the shifter.
Old Dec 11, 2008 | 02:42 PM
81c3's Avatar
81c3
what exactly do you guys mean by modify the boot?
Old Dec 11, 2008 | 03:42 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
At the tip of your boot were it meats the shift ****. It is bent over alittle bit. You have to unbend it. Then you push the c6 **** from the top outside to the bottom. So it will look like the **** is in side the boot. Slide it over the c6 post and screw it in. Slide the rest of the boot down and it snaps back in to the console. Here is a link on istall for a c6 shifter. Hope it helps.
http://forums.corvetteforum.com/c5-g...llation-5.html
Old Dec 11, 2008 | 04:01 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Might want to look at this thread before you buy.
http://forums.corvetteforum.com/c5-t...ct-review.html
Old Dec 11, 2008 | 04:08 PM
Davinss's Avatar
Davinss
I prefer the C6 shifter!
Old Dec 11, 2008 | 05:01 PM
dbaker's Avatar
dbaker
I've got the B&M Ripper and like it.I did the Anti-Venon mod with 2 washers and it's smooth,but firm.
The Delrin **** is great too!
\db
Carolina
Old Dec 12, 2008 | 02:10 PM
81c3's Avatar
81c3
Now look what you made me do!! Here I am trying to be as frugal as possible and buy used....then you post this! I just ordered an MGW. Thanks for the link!!
Old Dec 15, 2008 | 09:29 AM
Independent1
St. Jude Donor '08
^^Your welcome. Sorry about that
Old Dec 15, 2008 | 12:27 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Save your money and go for the delrin ****. 30 bucks and it lowers the shifter height by over an inch. The car shifts tons better.
Old Dec 15, 2008 | 02:17 PM
81c3's Avatar
81c3
Originally Posted by meadowz06
Save your money and go for the delrin ****. 30 bucks and it lowers the shifter height by over an inch. The cars shifts tons better.
Too late! Also the Delrin **** is imo
Old Dec 15, 2008 | 03:41 PM
meadowz06's Avatar
meadowz06
If you tried it and did not like it then go for the shifter. It was just a suggestion. I had a delrin in my other Z06, and I just ordered one for this Z06. Good luck.
Old Dec 15, 2008 | 08:25 PM
5800Z06's Avatar
5800Z06
I love the derlin ****. I wasn't sure if I would or not, but it is great. I like pushing to upshift instead of pulling.
Stock Z **** was
Also, I never hear of people suggesting to remove the demon key by using an open-ended wrench and using it as a lever to remove it (this is how I did it). Everyone says to pull it out with plyers, but I found the lever method easier. If you have a small enough open-ended wrench you can get it right in the slot on the left or right side of the demon key.
Old Dec 15, 2008 | 08:35 PM
LT1GMC's Avatar
LT1GMC
That one more reason for the C6 shifter, NO MORE DEMON KEY!!
I switched from the Hurst to the C6 Z06, and love it.
To Shifter questions
