Opinions please
Old Dec 14, 2008 | 04:02 PM
jobear's Avatar
jobear
Default Opinions please
Hey all,
Had the Vette lowered using the stock bolts the other day. He asked me if I wanted it all the way down and I said yes. The front went down 1/2 to 3/4 and the back down around 1". Question is -- "Is the back too low compared to the front?" Keep in mind I didn't want it slammed.
Also enclosng a pic of the back end with the new Corsas and flushed lights.
Thanks in advance.
[IMG][/IMG]
Old Dec 14, 2008 | 04:07 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Front may be a touch high compared to the rear, but mine is still stock height
Old Dec 14, 2008 | 04:10 PM
Dave Sweatt's Avatar
Dave Sweatt
Certainly won't hurt anything. Just check the alignment after you drive for a couple weeks and it settles.
Old Dec 14, 2008 | 04:28 PM
jrose7004's Avatar
jrose7004
Doesn't really look it in the picture but let it settle a couple of hundred miles and look again.
Old Dec 14, 2008 | 04:30 PM
tricep's Avatar
tricep
St. Jude Donor '09
Originally Posted by jobear
I lowered the front just a tad. It doesn't really appear to make a huge noticeable difference. I wouldn't worry about it. My first Vette did the same thing. I didn't have any problems at all. When I had it aligned, it was perfect.
Old Dec 14, 2008 | 04:40 PM
1SHADYZ's Avatar
1SHADYZ
Thats the same car isnt that? To me the 2nd picture looks lower then the 1st picture. Am I seeing right?
Old Dec 14, 2008 | 04:51 PM
damilleniumboy's Avatar
damilleniumboy
Nope.
Old Dec 14, 2008 | 04:59 PM
jobear's Avatar
jobear
same car different sides of the street 5 minutes apart.
Oh I see you photoshopped it for me lol, thanks, can I leave it that way?
Old Dec 14, 2008 | 05:02 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Looks great, be sure to get it aligned to for sure!
Old Dec 14, 2008 | 05:09 PM
tricep's Avatar
tricep
St. Jude Donor '09
The second pic has been slightly altered...
Old Dec 14, 2008 | 05:11 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Looks to me like the front needs to be lowered a little more but it looks okay as it sits. Just remember to go get an alignment after putting about 100 miles on it. I didnt get my alignment right away and it chewed my tires all up.
Old Dec 14, 2008 | 05:15 PM
1SHADYZ's Avatar
1SHADYZ
Ooooh alright nice. I thought I was loosing it hahaha.
Was that the most you can go on the stock bolts on the front or could they go lower? ... Jobear
Old Dec 14, 2008 | 05:53 PM
tricep's Avatar
tricep
St. Jude Donor '09
That looks like about it- give or take a millimeter. My Z has the front bolts removed and the back lowered on aftermarket bolts. The back can go lower-- thats it for the front.
Old Dec 14, 2008 | 07:11 PM
jobear's Avatar
jobear
Down all the way both front and rear
Old Dec 14, 2008 | 07:25 PM
1SHADYZ's Avatar
1SHADYZ
Tricep... Niiice!! Yeah I've heard about that, removing the bolts. How does it handle? Doesnt something have to be removed after taking the bolts out. The reason why Im asking is b/c I have the same problem with the front being a tad higher. I bought the car how it's sits the rear has aftermarket bolts. Let me know about how it is with the front removed. Thanks.
Jobear... Alright. Yeah I had the same problem as said up above. You going to keep it that way?
Old Dec 14, 2008 | 07:36 PM
rainman750's Avatar
rainman750
You can cut the front bushings to get lower. The biggest thing to make sure of is that you have the rake right. From front to rear, the rear is supposed to be slightly higher or the handling will suffer. Can't remember the the exact amount off the top of my head but 3/8 of an inch comes to mind. So, let it settle for a couple hundred miles and get it aligned, but definately check the rake.
Old Dec 14, 2008 | 07:59 PM
tricep's Avatar
tricep
St. Jude Donor '09
Tricep... Niiice!! Yeah I've heard about that, removing the bolts. How does it handle? Doesnt something have to be removed after taking the bolts out?
It handles just fine. I had a 2000 vert dropped the same way for years. No problems. The suspension is much stiffer in the Z though.
I'm not sure about what else was done/removed. I had one of the supporting vendors (Synergy Motorsports) do it for me.
To Opinions please
Old Dec 14, 2008 | 08:05 PM
The back does look lower than the front in those pics. Just my opinion, but I would want the back a little higher than the front.
Old Dec 14, 2008 | 08:53 PM
dobewillie's Avatar
dobewillie
I couldnt bring myself to lowering it all the way left two threads looks good
Old Dec 14, 2008 | 10:32 PM
1SHADYZ's Avatar
1SHADYZ
RAKE? Whats that?
