Scraping question
Old Dec 15, 2008 | 12:32 AM
Nightstick's Avatar
Nightstick
Default Scraping question
My 03 always, without fail, scrapes when I pull out of my driveway. No matter how slow I take it or at what angle. Driving up the driveway never scrapes. Ever. It's only a small scrape when I pull out I just can't figure out why it only does it one way. I want to lower it on the bolts but the scrape has me scared. Any ideas?
Old Dec 15, 2008 | 01:01 AM
bumble-z's Avatar
bumble-z
First off if I were you I would order and install a set of Fat Mamma's from CCA. They are a listed as one of our venders here on the forum. That will take care of the scraping of any bottom parts. As far as the problem backing out of your driveway, you might try and go out at an extrme angle and real real slow. Good luck.
Old Dec 15, 2008 | 01:16 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
We carry them too!
www.corvettemods.com
Old Dec 15, 2008 | 02:57 AM
DeeGee's Avatar
DeeGee
I guess the push from the rear driven wheels is just enough to lift the nose a fraction on the way up so it clears the air dam. The air dam is designed to flip back going forward but not going backwards. In that direction its going against the hinge so take it easy.
The frame savers (small wheels) that the guys are talking about are a great mod and are designed to strike the ground first. It should take the load off the air dam. I've also got a set of rocker rails fitted to protect the rockers. I'd say thats also a good idea if you plan to lower the car.
Whether you want to lower it is your call. How about reversing into the garage to see if it improves the problem? That way the air dam will be operating as designed and will quite happily take the scrape on the way out. JMHO
Old Dec 15, 2008 | 03:11 AM
PostShawn's Avatar
PostShawn
Mine is lowered all the way on the stock bolts. I scrape all the time. The front scrapes aren't a worry to me too much anymore. Mine has the frame saver wheels on the front as mentioned above. Various vendors here on the forums carry them. I have scraped in the middle a few times and that's scary. I really try to avoid that and never go over known locations to do that again. But with the front frame saver wheels I feel protected just fine.
Old Dec 15, 2008 | 04:59 AM
Nightstick's Avatar
Nightstick
Thanks. Looks like little wheels are in the future for me for Christmas. I'm gonna try backing up in the driveway later on today just to see if it helps.
Old Dec 15, 2008 | 07:50 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
You didn't say WHERE it scrapes. Nose, middle, underneath? Depending on where you scrape, spoilers, chin, belly, that's the area you want to addess.
No matter, you need to get those frame wheels. Also a VERY good item to have, especially for a lowered vette, is the frame rail savers. Those are invaluable for protecting your rocker panels from "highsticking" like when you get that scrape going over speed bumps and things.
Old Dec 15, 2008 | 08:06 AM
capehorn3's Avatar
capehorn3
Yea, mine scrapes when leaving my Dads house but not pulling in the drive way. Tried backing in, scraped both ways.
Old Dec 15, 2008 | 08:44 AM
Oldvetter's Avatar
Oldvetter
I have those "S" curve curbs in my development (you know, the ones where they can put driveways anywhere) and my car used to scrap. I had concrete put at bottom to make a ramp, no more scraping.
I also saw a removeable rubber ramp that you can buy and place there, it weighed 160 lbs. Here is a link:
http://www.bridjit.com/pages.php?pID=18
Old Dec 15, 2008 | 01:11 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I had a nose killin' driveway...
I just rented a concrete grinder and lowered the sidewalk.
Old Dec 15, 2008 | 04:29 PM
JanMan99's Avatar
JanMan99
My 2000 Coupe does the same thing backing off my driveway onto the street. It is not lowered either. I usually place two 2 X 4's where the driveway meets the street & I know the wheels will roll over them, even when I turn the front wheels. I take it slow & the air dam rarely scraps. Good luck.
Old Dec 15, 2008 | 05:04 PM
tricep's Avatar
tricep
St. Jude Donor '09
It is just annoying. It has never hurt anything. Those spoilers are tough. I thought sure I had broken mine many times-- I've even folded the whole thing over a few times (during a tow)
I go over everything...
sideways.
Old Dec 15, 2008 | 08:12 PM
kettemr's Avatar
kettemr
pull in on an angle.
Old Dec 15, 2008 | 08:53 PM
Jacks02's Avatar
Jacks02
I was thinking the same. Had same problem, went in/out of driveway at an angle, no more scraping.
Old Dec 15, 2008 | 09:54 PM
10U 99's Avatar
10U 99
yup
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Old Dec 15, 2008 | 10:00 PM
damilleniumboy's Avatar
damilleniumboy
I'm lowered all the way with the front bolts removed, and going out of the back garage in the alley, is no easy task my friend. The little front scraping won't damage your car. Unless it is a metal to cement grinding; then I would be worried.
To Scraping question
Old Dec 15, 2008 | 10:05 PM
jrose7004's Avatar
jrose7004
Mine is lowered all the way on stock bolts and the front airdam scrapes on about everything.
Old Dec 15, 2008 | 10:16 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I have had frame savers(little wheels) and rocker rails on mine for 4+ years and the middle air dam still scrapes a bit(even at an angle and driving slow) but even though it has scraped hundreds of times it does not do anything but put some scrape marks on the bottom of the plastic dam which I can't even see unless I crawl under and look. The center air dam can be replaced really easily and its cheap if I felt the need...Thats why they put the middle air dam on spring hinges, so it will fold a bit when going over obsticles or inclines/declines ...the scraping sounds 100 times worse than it really is.
The little wheels will protect the frame rails(in front) and other parts from being crunched or scraped but don't do much for the front center dam scrape problem...the center air dam is in front of where the little wheels are. Rocker rails save the rocker panels under the door and the car can be jacked under these rails w/o damaging the panels.
Old Dec 15, 2008 | 10:31 PM
Ryan L's Avatar
Ryan L
Before everyone tries to sell a part that may have nothing to do with the scraping... find out what's scraping first. I am assuming it's just the plastic air dam, which is no big deal. Most people either trim it down or remove it completely. I live in hot, humid Florida and have had mine removed for years. I am lowered 1.5" and never scrape a single thing.
If you are scraping the metal rails under the bumper, then that's a different issue, but I highly doubt that's your problem.
