Do C5's rust?
Old Dec 26, 2008 | 06:07 PM
C3Paul's Avatar
C3Paul
Default Do C5's rust?
I always wondered if the C5 frame rails were galvanized, or had any sort of rust proof from factory, or are they just steel tubes painted in black?
Old Dec 26, 2008 | 08:30 PM
Fast98's Avatar
Fast98
It must have some sort of rust proofing its not a toyota.
Old Dec 26, 2008 | 08:40 PM
bencini231's Avatar
bencini231
No rust that i know of.
Old Dec 26, 2008 | 08:45 PM
ErnieN85's Avatar
ErnieN85
Me too so I checked...........They are galvanized!
They don't seem to rust 113,000 miles in Pa and winter driving too
Old Dec 26, 2008 | 08:50 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
C5's have a hydroformed galvanized-steel chassis.
Old Dec 26, 2008 | 09:01 PM
tiojames's Avatar
tiojames
I have never seen rust on one, but the aluminum parts will corrode with the chemicals used for deicing roads unless it is washed off.
Old Dec 26, 2008 | 11:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The frames will rust and the aluminum parts will pit if you expose to them to salt and do not rinse the salt off. Trust me went thru this with a 99 FRC. It did not rust thru but it was a mess to clean up.
Old Dec 26, 2008 | 11:39 PM
Have never seen a C5 with rust on it. Have seen some of the aluminum components corrode though.
Old Dec 27, 2008 | 01:34 AM
Bell's Avatar
Bell
Rust does NOT seem to be a big problem but that doesn't mean there is none. Rust is iron oxide. Since we can't escape the oxygen in our atmosphere, any component which has iron in it will eventually rust. The hydroformed and galvanized frame rails mentioned above are steel (iron impregnated with some carbon atoms) coated with zinc (galvanized). If the plating ever starts flaking off (and there are a multitude of things that can start that), then the steel will rust. The body panels are not metal - no problem. And most of the engine components are aluminum. But there are still alot of steel components in the car and they will rust. Just take your wheels off and you'll find lots of them in/around the wheel well areas (mainly suspension components). Again, as I started off. Not a major problem on Corvettes.
Old Dec 27, 2008 | 02:19 AM
DeeGee's Avatar
DeeGee
Having read "All Corvettes Are Red", the designers and engineers were paranoid about weight to get the car down to its target weight. I guess using iron components other than where absolutely essential wasn't an option
Can't say I've seen anything on mine thats rusted although its not out in the rain much
Old Dec 27, 2008 | 10:00 AM
rws.1's Avatar
rws.1
They rust.
The steel crossmember ahead of the rear bumper fascia definitely rusts.
Trust me... I have had to remove the surface rust and repaint mine.
Old Dec 27, 2008 | 10:10 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Anything that is steel will rust at some point in its lifetime.
When people ask if my dog bites my reply is usually ....anything that has teeth .....does "bite".
So like I said anything that is steel will rust.......
Old Dec 27, 2008 | 10:17 AM
71vetteinva's Avatar
71vetteinva
I don't think you need to worry about it all. Minor surface rust won't hurt your car. Just flush the bottom when you wash it and enjoy.
There is some minor pitting on some of the aluminum components under my 2000. Mine came from Illinois, so I guess it was driven in the snow. Anyway, I would guess it would take decades to actually impact the operation of the vehicle, maybe never during it's operational life. (That's a far cry from the C3, rust on the frame rails can be a big problem on those cars.)
Has anyone actually seen or head of a C5 damaged so badly by corrosion that a part needed to be replaced? I never have.
Seems to me like quality materials were used to construct the frame and suspension components...
Old Dec 27, 2008 | 01:09 PM
Ryan040675's Avatar
Ryan040675
Originally Posted by rws.1
They rust.
Shortly after I bought mine I started going over it with a magnifying glass. I found a little of the "white" corrosion on my rear bumper rail. The car originally came out of Jersey but then went south. There was no rust per say, but there would have been eventually if I didn't do something about it. I pulled the exhaust, wire brushed it all down, and painted it with a rubberized undercoat.
Old Dec 27, 2008 | 03:58 PM
Crab's Avatar
Crab
Old Dec 27, 2008 | 04:06 PM
El Zappo's Avatar
El Zappo
From: Remember the average response time to a 911 call is over 6 minutes. The average response time of a .357 magnum is 1400 fps.
My rotors rust every time I wash the Vette.
Old Dec 27, 2008 | 08:35 PM
dobewillie's Avatar
dobewillie
good posts
To Do C5's rust?
