Catch can ?
Old Jan 1, 2009 | 04:06 PM
Dave68's Avatar
Dave68
Originally Posted by Rich-L
Dave
On the 2004 LS1 does a Catch Can really help? No major mods and no raceing.
Rich
Yes, although how much it catches will also depend upon how much blowby your particular engine produces. Even C6s with their internal oil/air separators allow oil from blowby to be ingested by the engine. One of the things I don't like about catch cans is the width of their "cans". The wider the can, the more likely that oil aerosols will be pulled out during low rpm, high turbulence driving. Having many ounces of oil sloshing around under high vacuum cannot be good, IMO.
And for those who are considering buying a $20 filter that has a clear polycarbonate body - don't do it! As I mentioned, those units are rated to 125 degrees F MAX and are often not suitable for contact with fuel and even some synthetic oils. Any resulting vacuum leaks will allow unfiltered air to be pulled into the intake.
Old Jan 1, 2009 | 05:52 PM
karateboi87's Avatar
karateboi87
Are there no products out there that can be substituted for the polycarbonate body? Obviously it'd cost more. Maybe someone can try that out.
Old Jan 1, 2009 | 07:46 PM
Dave68's Avatar
Dave68
I'm using a glass-body version right now but the disadvantage of glass is that it is more of an insulator than a conductor. Fortunately, my setup has two things going for it:
1. The top part is aluminum, which is a good conductor.
2. The unit is located in a cool area of the engine bay (up front), so that the hot blowby gasses "see" a fairly significant temperature differential when they slam against the aluminum and somewhat cool glass body, which encourage airborn oil to coalesce on the cooler surfaces.
Some catch cans contain a "sight tube", but over time, this tube will become dark and harder to see through. Periodic cleaning is required if the oil level is expected to be easily observed at all times.
Old Jan 1, 2009 | 10:54 PM
T VETTE's Avatar
T VETTE
