I bought a 1999 Corvette yesterday and on the way home it gave me low tire pressure warning. This morning I checked them. They had around 25psi all the way around. I aired them up to 42 front(tire said 44) and 49 rear(tire said 51). Now I am getting a high tire pressure warning. My local Chevy dealer said to look at the sticker on the door as did the owners manual. Well it is gone. Can someone tell me what pressure I should be running?
You should be running 30 psi in the tires. The sensors are designed to come on when you go to 25 psi or below (low pressure warning) and will also tell you when you have way too much air in them.
Thats what I shoot for,,gives a little fudge factor,,they are rarely full cold when I'm at a handy air source. +2 lb is better than -2lb IMO for DD type driving!!
I run F1 supercars on my Z, many of my friends run Michelin and others but I like the feel of my GY's...
With that said, I like 28-29 in the winter and 22 - 25 in the summer. The reason I mentioned the other tires with harder compounds is that i have heard many people run them at higher pressures.
My tires wear even and long and are still soft enough to bite hard when called upon.
Watch your tire wear and feel the grip, since i have a Z i don't have the benefit of sensors but i do watch them pretty close and seat-o-pant gauge is real close usually.
Mine won't stay the same all the way around. My left rear drops to 25lbs after a cpl of weeks. Two others fluctuate after a cpl of weeks but not as much as the one. I hate leaving somewhere and hear the alarm sound and see the lbs dropped. I don't use runflats so always get scared that I have picked up a nail or something and have a flat.
