passenger window regulator
Any other suggestions?
Do not give in to the evil
If you show signs of weakness you will pay the price
retrieve that jar of marbles and hold on to them tightly
Better question is why would you need a denali and a tahoe two huge gas guzzling land yahts?
I just about blew a hole in my shorts when the parts house handed me the invoice for the regulator assembly. The counter guy lamented I sounded like a snow tire on ice.
Replacing the regulator was easy. Have to hand it to the engineers on that one. Now the oil pressure sensor is another matter. The engineers were definitely smoking wacky tobacky during that design review.
As for the wife, that is a tough call. I still have my Vette after three oil pressure sensors, one window regulator, one hazard switch (another wacky tobacky special), left headlamp motor failure, parking light enclosure failure both sides, left rear wheel bearing failure, then later left front wheel bearing failure, end link replacements all four corners, gas gauge sensor replacement, and now the ABS/Active Handling repair is pending. Yep got the infamous check ABS/Active Handling/Traction Control alert when the weather is warm. This one may be the straw that breaks the camels back.
You gotta love the car or it is a lost cause.
. If I was close I'll do it for you. Good luck.
Can't you buy just the motor instead of a whole new regulator? I've replaced both motors on my Camaro, it's only difficult the first time because you have to drill out the rivets. Once they are replaced with bolts it makes future repairs a snap.
Someone pm'd me in regards to a used unit. I am getting some prices for new ones also before I decide whether or not to buy used.
