Gears question
Old Jan 12, 2009 | 12:10 PM
STLKillerC5's Avatar
STLKillerC5
Default Gears question
I have a 2000 coupe. I've done heads/cam, intake and exhaust mods. I have about 400 RWHP on the dyno. I have heard a lot that upgrading my gears to 3:73 or 4:10s will make a huge difference and increase torque. Does anybody have advice on this? Actual dyno results? estimated cost of replacing gears? What does replacing gears affect....do I need another tune?
Old Jan 12, 2009 | 12:22 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Go to 3.73 or 3.90s. 4.10s maybe a bit too much if you plan on having more power down the future.
Old Jan 12, 2009 | 12:28 PM
iced98lx's Avatar
iced98lx
You'll need another tune, but a great way to get to wherever you're going faster
Old Jan 12, 2009 | 12:30 PM
RespondsWithGif's Avatar
RespondsWithGif
You won't see any results on a dyno with gears. Replacing gears affects acceleration by increase total torque output but has the bad side effect of losing some speed in each gear.
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Jan 12, 2009 | 12:33 PM
FactoryRaceCar
Originally Posted by Willfulone
Peace
Chip
Chip
Old Jan 12, 2009 | 02:32 PM
STLKillerC5
How much speed should I expect to lose with each gear?
Old Jan 12, 2009 | 02:37 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
I have 3.90's and they are insane! I can roast my tires in the first 3 gears.
Old Jan 12, 2009 | 02:47 PM
RespondsWithGif
You will lose the same percentage the old gear ratio is vs the new ratio. For example, if you went from a 3.42 to a 3.90 (12.3% difference from 3.90 to 3.42) you will lose 12.3% of your speed at any given rpm. So first gear will go from 52.31mph to 45.87mph @ 6000prm.
Old Jan 12, 2009 | 02:48 PM
crosstheline's Avatar
crosstheline
Check my profile out and you will see that we have very similar set-ups. I went with the 3:73's with a 3600 stall converter (from 2:73's). Best mod for the buck out there.
As a matter of fact I work off of 270 and Olive avenue. Maybe if we could get some decent weather I could take you for a ride so you could get a feel for it.
Old Jan 12, 2009 | 02:51 PM
crosstheline
Originally Posted by 01silvercoupe
You will lose the same percentage you went up in gears. For example, if you went from a 3.42 to a 3.90 (12.3% change) you will be lose 12.3% of your speed at any given rpm. So first gear will go from 52.31mph to 45.87mph @ 6000prm.
I stated I went to the 3:73's but if I had M6 I would go with the 3:90's. For me it's not about top end it's how fast I can get there in a shorter amount of time. Even with the 2:73's I never had intentions of going 175 mph.
Old Jan 12, 2009 | 04:20 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
I love my 3.73s Its like getting a new car with a whole lot more power The only downside is rear tire wear Oh and I have a 3200 stall converter also
Old Jan 12, 2009 | 04:29 PM
black98c5's Avatar
black98c5
3:73's w/3600 stall here. Best mod for the money.
Old Jan 12, 2009 | 04:53 PM
argonaut's Avatar
argonaut
As a DIY project the easiest way to change the gears is to buy a whole new differential and install it. New or rebuilt diffs from vendors are pretty expensive - > $1K. But if you keep your eyes open you can sometimes see used ones for sale. Its very easy to find 3:42 takeouts for sale in the $5-700 range, hard for 3:73 and up, although I have seen a few in the last couple months. I don't know what a shop would charge to install, quite a bit I would think, you have to drop the rear cradle so its more than just a little work.
Old Jan 12, 2009 | 06:30 PM
94legaleagle's Avatar
94legaleagle
you need to do gears AND a stall converter - go w/ 3.73 gears and a 3200 or 3600 stall converter - I didn't look to see what your mods are, but check my sig for my mods - I'm running 3.73's and a 3200 stall - LOVE EM!!!!!!!!
Old Jan 12, 2009 | 06:31 PM
CCA Corvette Parts
Chip
What's up brother
Peace
Chip
Old Jan 12, 2009 | 07:44 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
For a H/C car, 4.10s are the recommended gear on a 6spd! Its awesome for the street, goes perfectly with the 6-spd trans.
I still get 28-30 mpg on highway
To Gears question
Old Jan 12, 2009 | 07:55 PM
dobewillie's Avatar
dobewillie
great post learnin more every day thanks
Old Jan 12, 2009 | 08:17 PM
vetterlatethannever's Avatar
vetterlatethannever
I think 3.90s would be a great gear to go with on that setup.
Old Jan 12, 2009 | 08:51 PM
C5XTASY's Avatar
C5XTASY
Go with the 3.73s. And, as suggested, put a stall in at the same time. Yank SS3200 here and I love it. See my sig for other mods (H/C/Intake, etc., etc). I would sugest you may want to just buy a 3.73 differential. I tried to have mine rebuilt and had whining issues. They tried new gears again, in the same carrier, and, for whatever reason, weren't able to shim it up to proper specs. Ended up buying a new carrier which they were able to shim up. Wasn't fun. I split the cost with my tuner and the rebuilder. He had never had a 3.73 gear installation failure before.
Ed
