Balky headlight
Right side headlight does not raise at all times. I can turn off the headlamp switch, rotate the manual lift **** a quarter turn or so and it then raises fine via the motor.
When closing however the operation appears normal but when fully closed the motor continues to run for about 4~6 sec making a rather noisy rat-a-tat-tat sound.
As the mechanism does raise/close via the motor it does not seem to reflect the typical gear replacement problem and suspect a switch orientation/positive stop situation.
There are far more knowledgable folks on this type of problem than I however and thought I'd search for a few clues and/or solutions.
Any ideas are appreciated. Thx.......
As a new member it takes a bit of time to learn how to negotiate the forum. Wound my way thru the sticky as suggested and discovered very concise repair suggestions - complete with sound effects to verify the problem. Will order parts today - know what I'll be doing Saturday
