Automatc
sometimes feels like i have to give it alot of gas..for the car to pick up. the throttle response doesnt feel very quick. almost like on a delay.
is there any good products to improve the throttle response?
I read a thread from one tuner who was trying to remap the shift points for this very reason. Not sure how far it went and I cant find the link. Apparently the compromise is performance over reliability.
Like you I find it frustrating so I tend to drop to 3 or even 2 if I want a quick pick up. I also find it annoying when it tries to upshift on a bend. Some of the back roads here are quite twisty so again I drop a gear.
He did my 2004 A4, and the throttle response is much better than stock.
You'll find links to him in the following thread...
http://forums.corvetteforum.com/c5-g...rder-tune.html
Wow, lots of guys with "Chuck CoW" tunes here, including me.
I just got my ECM back from Chuck, so I haven't had a chance to try it out yet, as the roads here are all snow and ice.I had talked with Chuck for quite a while prior to sending him my ECM and he clearly explained the soggy throttle response. As you may (or may not) know the Corvette throttle body is NOT connected via a mechanical cable linkage directly from the gas pedal. There is a sensor for the gas pedal, which transmits electrical signal to a small motor on the throttle body, and it is that small motor which opens and closes the throttle. So, you actually have "throttle by wire".
The factory settings call for the throttle response to be very slow, especially at part-throttle operations. Chuck explained that at 20% gas pedal depress, the throttle might be only 3% open (not sure if these are exact %'s, but they're close). So on a stock tune, we get what feels like a sluggish car. One of the things Chuck does is increase the settings on the throttle body motor, so that at 20% gas pedal, the throttle body opens to 9%. So this produces a much snappier-feeling car.
Hope this helps.
The factory settings call for the throttle response to be very slow, especially at part-throttle operations. Chuck explained that at 20% gas pedal depress, the throttle might be only 3% open (not sure one these exact %'s, but they're close). So on a stock tune, we get what feels like a sluggish car. One of the things Chuck does is increase the settings on the throttle body motor, so that at 20% gas pedal, the throttle body opens to 9%. So this produces a much snappier-feeling car.
Hope this helps.
Hope this helps.
this makes sense. if the throttle body opening pre-tune is biased toward the end of the pedal travel the car would respond in a manner as the one i drove did...
