Jacking a Vette.
Old Jan 24, 2009 | 08:59 AM
SharpCrease's Avatar
SharpCrease
Default Jacking a Vette.
My buddy that owns a 1999 C5 says that you should never use any kind of floor jack to lift it unless you open every single door on it which includes the drivers/Pass doors,,,,trunk,,,,hood... Is this true??? He says that if you jack it up with a floor jack with the doors closed could mess up the alignment and will cause opening and closing issues.....
Old Jan 24, 2009 | 09:18 AM
dndrsn's Avatar
dndrsn
I have used a floor jack to lift my car one wheel at a time, both wheels on one side, and either end. I have never had any issuses with panel or door alighment.
Old Jan 24, 2009 | 09:20 AM
Lowcash's Avatar
Lowcash
Old Jan 24, 2009 | 09:29 AM
SharpCrease
Ok thanks.... was worried for a minute because I've done it a few times myself.
Old Jan 24, 2009 | 09:31 AM
jrose7004's Avatar
jrose7004
That's me!
Old Jan 24, 2009 | 11:24 AM
rebelheart's Avatar
rebelheart
Seems very odd that they have jacking points if you arent supposed to use em!
Old Jan 24, 2009 | 11:26 AM
DeeGee's Avatar
DeeGee
Thats a myth thats carried over from the C4
The C5 is stronger than an ox
Jack away but use the jacking points (and pucks for the side points) or you may risk rocker panel damage
Old Jan 24, 2009 | 11:49 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I've heard this before and there has been a post or two about it in the past. Bottom line.....not an issue with the C5. Maybe earlier generations but as long as you follow the instructions for the proper jacking of your C5 you'll have not worries.
Here's a great post that will give you everything you need to know about jacking your vette.
http://forums.corvetteforum.com/c5-g...l?forum_id=103
To Jacking a Vette.
