programming key fob
Old Mar 7, 2017 | 10:13 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by could be true
Hello, do you have to reprogram the fob after changing the battery?
Are you talking about the car battery, or the FOB battery.
Typicality changing the car battery doesn't require it, but a new FOB battery may require holding the lock & unlock buttons on the remote simultaneously to reprogram it.
Good luck... GUSTO
Old Mar 21, 2017 | 11:42 AM
TX82CE's Avatar
TX82CE
1st Gear
Default 99 fob
Need help here-hubs' 99 got new battery and new batteries in fobs. followed manual to reset fobs, all went well. BUT, upon exiting vehicle, car locked and unlocked itself, then locked , then armed. Yikes. Passive entry is Off on fobs, checked options and passsive lock is off. what the heck? Should I just remove batteries from fobs and go back to "el manual" lock /unlock? Creepy.
Old Mar 21, 2017 | 12:39 PM
Carl Timonen's Avatar
Carl Timonen
Mine did that a couple of times after changing the batteries. All I did was to cycle the passive switch on the fobs a couple of times, reset the memory and it seemed to work.
Old Mar 22, 2017 | 10:42 AM
Phanni's Avatar
Phanni
Check the part #s on the fobs.
