Most Unique Feature - Bose
Old Jan 26, 2009 | 07:17 PM
jobear's Avatar
jobear
Default Most Unique Feature - Bose
One of the most unique features in the C5 is the SCV feature on the stereo system. I know most don't think much of the Bose unit but to have the volume go up and down according to interior noise level is a great feature. I have owned more expensive cars without that feature and am constantly turning down the radio when I come to a stop. Does this work by speed or sound? What do you think? Do you have it in any other cars?
Old Jan 26, 2009 | 07:32 PM
R Devil's Avatar
R Devil
My S/O has it in her 04 Impala...........
Old Jan 26, 2009 | 07:38 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
I can't hear the stereo in my Z06 to save my life (yes I like it that way). Maybe I should remove the head unit completely and install a twizzlers dispenser.
Old Jan 26, 2009 | 07:41 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
Based on my observations, I think it goes by speed.
I can detect a pronounced volume change every time I change speed by 10 mph... at 40, 50, 60, etc. there is an abrupt change. I do like that I can manually change the amount of compensation it provides. At maximum, it gets too loud too fast, so I keep mine one notch down and it seems just right. It's just too bad the sound system itself isn't the best... but that's an upgrade for next year.
Old Jan 26, 2009 | 07:58 PM
The Stranger's Avatar
The Stranger
Can this feature be turned off?
Old Jan 26, 2009 | 08:00 PM
Alaskanpilot
Yes... the outside plastic ring around your volume **** (this ring has a tab on it) controls this feature. turn it all the way off (counterclockwise) and it will be disabled. When it's on, I think there are three levels of compensation it provides. So the **** has 4 positions it can be in... Off, and then the three set positions.
Old Jan 26, 2009 | 09:07 PM
c5blkvetteguy's Avatar
c5blkvetteguy
In my car the pipes are roaring and the tunes are blasting! Turn it down...never!!
Old Jan 26, 2009 | 09:10 PM
Turbopower87's Avatar
Turbopower87
My Mazda3 did it by speed, I would assume its the same in the vette. Many low end cars now come stock with this feature now too.
Old Jan 26, 2009 | 09:35 PM
Oldvetter's Avatar
Oldvetter
It is based on speed, following is from the owner's manual:
SCV: Your system has a feature called
Speed-Compensated-Volume (SCV). With SCV, your
audio system adjusts automatically to make up for road
and wind noise as you drive. Set the volume at the
desired level. Move the control ring behind the upper
**** to the right to adjust the SCV. Then, as you drive,
SCV automatically increases the volume, as necessary,
to overcome noise at any particular speed. The volume
level should always sound the same to you as you drive.
If you don’t want to use SCV, turn the control all the
way down. Each notch on the control ring allows for
more volume compensation at faster vehicle speeds.
Old Jan 26, 2009 | 09:36 PM
damilleniumboy's Avatar
damilleniumboy
My stang had it too, and I'm not really impressed with the stero system of the corvette.
Old Jan 26, 2009 | 10:08 PM
UKXPAT's Avatar
UKXPAT
totally, I think that the stock Bose system is a POS. There is a saying "No highs, no lows...it must be a Bose" which is totally correct.
I do think that for the original sticker price of the Vette they really should have put in a "decent" sound system. I have a convertible and love driving on the freeway with the roof down, but the sound when the roof is down and you're doing 70mph is TERRIBLE. I will be installing a decent sound system when I get some "spare" money but in the meantime I'll just have to live with it !
Old Jan 26, 2009 | 10:33 PM
bencini231's Avatar
bencini231
I think it works off of the speed. I have the same one in my truck also.
Old Jan 27, 2009 | 06:57 AM
Oldvetter's Avatar
Oldvetter
See post #9
SCV = Speed Compensated Volume
Old Jan 27, 2009 | 08:00 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
most gm radios have had that feature since the 90's not a bose thing
Old Jan 27, 2009 | 08:06 AM
Dominic Toretto's Avatar
Dominic Toretto
Thanks Barry, never looked into inquiring what the hell that is. I'll be trying this out today, not sure how fast I can get with the roads icing over though LOL.
-Alex
Old Jan 27, 2009 | 08:07 AM
Robls6's Avatar
Robls6
My bose radio sounded the best the day I ripped it out and replaced it.
Old Jan 27, 2009 | 08:40 AM
angman5's Avatar
angman5
With headers cam,heads borlas no cats I can't hear s.... out of that Bose system, but nothing like sweet LS1 music to make you
To Most Unique Feature - Bose
Old Jan 27, 2009 | 08:59 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I'm about to upgrade my head unit to a DD NAV/MP3 system. Instead of the Bose harness needed to work the stock factory system/speakers, is it easier to bypass the harness and just install new/better speakers? Is it that simple or is other electronics modifications required?
Old Jan 27, 2009 | 09:03 AM
Bigstik's Avatar
Bigstik
Every gm i have driven since then has it.
Old Jan 27, 2009 | 10:05 AM
Robls6's Avatar
Robls6
A buddy did mine (pentavolvo on this site) He ran all new wiring from the new head unit to the amp and speakers. We went with a single 4 channel Alpine amp with one 12" Elemental Designs subwoofer and 2 Elemental Designs component speakers in the doors. The rear speakers were completely eliminated. The whole setup cost me about $1200 including his time to install. It sounds 1000 times better than stock.
