Squeaking sound ?
Old Feb 14, 2009 | 10:36 PM
slverc5's Avatar
slverc5
Default Squeaking sound ?
I've started to notice a squeaking sound in front and back of the car- weird thing is though that it only happens when the temps go about 30 degrees and below. First I thought it was the suspension/shocks - well I've since replaced them, even replaced my sway bars -no change- then I though maybe the front air dam -but why only in the winter. Can't describe it in words but the closest I can describe it is when your shocks or coils are worn out and they make they squeaking sound or like a door hinge that don't have any oil or lubricant -anybody else have this problem maybe a solution.
Old Feb 14, 2009 | 10:56 PM
dobewillie's Avatar
dobewillie
weird
Old Feb 15, 2009 | 01:16 AM
Lone Ranger444's Avatar
Lone Ranger444
I got the same problem with my C5. I thought maybe it needed a grease job so I have on set up for next week. I glad you did the shocks, I thought that might be it too. We got a lot of road work going on in town and I thought going over the rough roads caused it. Let me know what you found out. I know mines underneath the car front and back.
Old Feb 15, 2009 | 01:35 AM
Myalterego's Avatar
Myalterego
Have you tried lubricating the sway bar bushings with Lithium grease?
Old Feb 15, 2009 | 03:14 AM
DeeGee's Avatar
DeeGee
Heres the Troubleshooting guide from the manual. Its for the rear but I guess the front is the same
Document ID# 724511
2002 Chevrolet Corvette
Noise Diagnosis - Rear Suspension
Step
Action
Yes
No
DEFINITION: Any noise emitted from the rear of the vehicle that is induced by VEHICLE SPEED or DRIVING TERRAIN as related to the rear suspension.
1
Did you review the General Description and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Suspension General Diagnosis
2
Verify that the rear suspension is noisy.
Is the rear suspension noisy?
Go to Step 3
System OK
3
1. Shift the transmission into Park.
2. Turn the ignition off.
3. Bounce the rear of the vehicle in order to duplicate the noise.
Is the complaint noise present?
Go to Step 4
Go to Step 5
4
1. Bounce the rear of the vehicle. Use a J 39570 in order to locate the source of the noise.
2. Repair or replace the suspect components as necessary.
Did you complete the repair?
Go to Step 20
5
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Inspect all of the rear suspension components for any damage.
Are any components damaged?
Go to Step 6
Go to Step 7
6
Repair or replace any damaged components.
Go to Step 20
7
1. Inspect the tires for proper inflation. Refer to Tire Inflation Pressure Specifications in Maintenance and Lubrication. Correct the tire inflation pressure as necessary.
2. Inspect the tires for unusual wear. Refer to Tire Diagnosis - Irregular or Premature Wear in Tires and Wheels.
Does either tire exhibit unusual tread wear?
Go to Step 8
Go to Step 10
8
1. Rotate the tires. Refer to Tire Rotation in Tires and Wheels.
2. Road test the vehicle.
Is the noise now emitted from the front of the vehicle?
Go to Step 9
Go to Step 10
9
Replace the tires that are causing the noise.
Go to Step 20
10
Ensure that the park brake cable is secured properly.
Did you service any components?
Go to Step 20
Go to Step 11
11
Ensure that all of the wheel nuts are tightened to the correct specification. Tighten as necessary. Refer to Fastener Tightening Specifications in Tires and Wheels.
Did you tighten any of the wheel nuts?
Go to Step 20
Go to Step 12
12
2. Use your hand to push and pull the shock absorbers.
Is either shock absorber loose?
Go to Step 13
Go to Step 15
13
1. Inspect the shock absorber fasteners for the correct fastener tightening specification. Tighten as necessary. Refer to Fastener Tightening Specifications in Rear Suspension.
2. Use your hands in order to push and pull the shock absorber.
Is the shock absorber loose?
Go to Step 14
Go to Step 20
14
Replace the loose or worn shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
15
Use your hands in order to push and pull on the rear axle tie rod.
Is the rear axle tie rod loose?
Go to Step 16
Go to Step 18
16
1. Inspect the rear axle tie rod fasteners. Tighten as necessary. Refer to Fastener Tightening Specifications in Rear Suspension.
2. Use your hands in order to push and pull on the rear axle tie rod.
Go to Step 17
Go to Step 20
17
Replace the rear axle tie rod as necessary.
Go to Step 20
18
1. Start the engine with the drive wheels off of the ground.
2. Shift the transmission into Drive.
Caution
Do not spin the drive wheels faster than 55 km/h (35 mph) as indicated by the speedometer. This limit is necessary because the speedometer indicates only one half of the actual wheel speed when one drive wheel is spinning and the other drive wheel is stopped. Personal injury and damage may result from high speed spinning.
Important
This step will require the assistance of another person to maintain the drive train speed. Do not use the cruise control to maintain the drivetrain speed.
3. Increase the drive wheel speed until the noise is at the most audible level.
Important:
Do not allow the stethoscope to contact any moving components.
4. Use J 39570 in order to locate the source of the noise.
Does either wheel bearing exhibit noise?
Go to Step 19
Go to Step 8
19
Replace the wheel bearings. Refer to Wheel Bearing/Hub Replacement - Rear in Rear Suspension.
Go to Step 20
20
Operate the vehicle in order to verify the repair.
Does the system operate normally?
System OK
Go to Step 3
Document ID# 724511
Old Feb 15, 2009 | 04:07 PM
slverc5's Avatar
slverc5
Document ID# 724511
Step
Action
Yes
No
1
Go to Step 2
2
Go to Step 3
System OK
3
Go to Step 4
Go to Step 5
4
Go to Step 20
5
Go to Step 6
Go to Step 7
6
Go to Step 20
7
Go to Step 8
Go to Step 10
8
Go to Step 9
Go to Step 10
9
Go to Step 20
10
Go to Step 20
Go to Step 11
11
Go to Step 20
Go to Step 12
12
Go to Step 13
Go to Step 15
13
Go to Step 14
Go to Step 20
14
Go to Step 20
15
Go to Step 16
Go to Step 18
16
Go to Step 17
Go to Step 20
17
Go to Step 20
18
Caution
Important
Important:
Go to Step 19
Go to Step 8
19
Go to Step 20
20
System OK
Go to Step 3
Document ID# 724511
Thanks Deegee - that's very detailed But I did try to bounce the vehicle - no noise heard, only happens with temp of 30 degrees and lower - and only if I hit small bumps even getting off my driveway if I get off my driveway a little faster, weird thing is, when I back up on the driveway faster than I should, I would hear the noise only in the front but getting off my driveway I would hear the front and back - going thru small bumps on the road will make the noise. Replaced ym shocks with C6 Z51 shocks -no change, replaced the sways with '99 Z51 sways - no change -lubricated the sways before installing them -this started before I replace my old shocks and old sways and by the way -my car only have 20+ K miles -not really a high mileage car for an 03. Drove the car today about 35 deg where I live -didn't hear the sound - not worried -just annoying sometimes
Old Feb 16, 2009 | 07:28 PM
slverc5's Avatar
slverc5
Well, guess it's just me and Lone Ranger444 who have this problem. I did a search and came up empty
Old Feb 18, 2009 | 10:10 PM
ValkWing's Avatar
ValkWing
Default I too hear the squeaks when it is cold
If it's below about 35 degrees I get the same squeaks until it gets warmer. I have no idea what causes it either...
Old Feb 18, 2009 | 10:35 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I squeak too...
I think its from the front.
It is anoying.
Old May 15, 2009 | 01:00 PM
jimcork1's Avatar
jimcork1
Say hello to the Lone Ranger because I have squeek front and rear.
I replaced the sway bars and bushing with new z06 parts. No change.
I lubed with silicon lube the shock tops and bottoms (remember you can only dobber on vs total removal)
A frame bushings spray silicon
Still the f/r squeeks both left and right sides.
I am thinking shocks but with F45 . I have an extra set I bought from new car take offs during mod time so I am thinking of installing these. My thoughts are the shock strut rod is squeeking at the top where it enters the cylinder.
My C5 sounds like a log wagon below 35 mph (any temps) but above 130 varooooooooooooom..
So tell Clayton Moore and Diablo are not forgotten, neither is Tonto
Old May 15, 2009 | 02:07 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Originally Posted by Stickman81
I squeak too...
It is anoying.
That happens to me sometimes, too. I've noticed that if I change the shock settings from tour to sport or performance for awhile, the noise goes away. I can put it back on tour for several hundred more miles before that annoying creaking sound returns at low speed over speed bumps. That's the only time I ever notice it happening.
To Squeaking sound ?
