Flat battery!
Old Feb 15, 2009 | 10:14 AM
C5Clive's Avatar
C5Clive
Default Flat battery!
Tried to start this am, battery completly flat no display or anything.
Was working on the car painting etc with the hood up for a couple of hours a day for 4 days without starting the car then ran diagnostics in the the DIC last night, would this be enough to drain the battery or could it be something else?
Old Feb 15, 2009 | 10:18 AM
DeeGee's Avatar
DeeGee
Unlikely in itself.
What type of battery is it? Is it an AGM or a lead acid? How old is it?
Also, is the car a DD? Do you run short trips that may slowly drain the battery?
If so, it would be worth giving it a good overnight charge to see if you can bring it back to life.
If its an old one maybe best to change it on spec. Most of the latest batteries will do OK
Heres an analysis I posted a while ago. Run down the thread and you'll see the spec you need for the Vette:
http://forums.corvetteforum.com/show...Battery+Thread
Old Feb 15, 2009 | 11:37 AM
C5Clive's Avatar
C5Clive
Originally Posted by DeeGee
Unlikely in itself.
Thanks great post, no the car is not a DD the batterys 4 years old 175000 miles. its on charge now it was down to 10% so I think all the lights on in the week and not running the car has flattened it, the last run in the car was only 5 miles as are most of its runs lately.
Clive
Old Feb 15, 2009 | 11:40 AM
DeeGee's Avatar
DeeGee
Clive
See how you go after a charge. If it behaves then great. If it shows signs of running down again maybe time for a change. This car is hard on batteries so it's not worth getting stranded. Also you may get a bunch of weird electrical gremlins as it dies.
Old Feb 15, 2009 | 11:50 AM
C5Clive's Avatar
C5Clive
Thanks for the great advice, its up to 41% now so we will see if it hold the charge, if not new battery time.
Clive
Old Feb 16, 2009 | 08:55 AM
C5Clive's Avatar
C5Clive
Clive
Latest update took battery tp Auto Zone checked it out toast! So put a new 1 in everthing is fine now, thanks for all the info.
Clive
Old Feb 16, 2009 | 11:52 AM
jovette's Avatar
jovette
Interesting.........never heard the description "flat" applied to a battery before............Usually "dead" is associated with a bad battery, and "flat" to a bad tire............or a girlfriend I had years ago Wonder if the O/P ever got a dead tire?
Old Feb 16, 2009 | 03:31 PM
DeeGee's Avatar
DeeGee
Clive
Old Feb 17, 2009 | 11:30 AM
C5Clive's Avatar
C5Clive
Flat tire, flat battery, same thing!
Who cares its fixed now.
Old Feb 17, 2009 | 03:43 PM
Smart move just getting it checked out. At least you know you have a good one in there now.
Old Feb 17, 2009 | 03:45 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
I just replaced mine , alittle while ago, good luck
To Flat battery!
