Programming TPS
Old Feb 18, 2009 | 10:23 PM
AWSUMC5's Avatar
AWSUMC5
Default Programming TPS
I just put new batteries in my pressure sensors (C5 Y2k) and need to re-program. Anyone know where I can find the process to re-program?
Thanks.
Old Feb 18, 2009 | 10:31 PM
rws.1's Avatar
rws.1
Search is your friend
Tech Tip
Resetting Tire Pressure Monitors -- 1 of 1
Date Published: 2001-07-02
Submitter's Name: Chris Palfi
Email Address: Private
Corvetteforum.com Member Alias: Brazen C5
I used this message forwarded from a fellow forum memeber and it worked just as described. Thought I would post for anyone else that may need to reset their TPMs. 1) Turn ignition on 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Feb 18, 2009 | 10:44 PM
AWSUMC5's Avatar
AWSUMC5
Thank you very much. I hope this goes as well as installing the batteries.
Old Feb 19, 2009 | 12:10 AM
DeeGee's Avatar
DeeGee
I used a magnet from an old car speaker. I hear that an old computer hard drive has one that will do the job.
Old Feb 21, 2009 | 10:22 PM
cubski's Avatar
cubski
Used a car radio magnet worked fine.If they do not train get a sttronger magnet.Good luck.
Old Jul 1, 2011 | 02:34 PM
Dave1998's Avatar
Dave1998
I needed a stronger magnet for the 1 new replacement sensor I trained last night. The wand with magnetic pickup trained the 3 orignal working magnets just fine
Dave
To Programming TPS
