Small portable air compressor
Old Feb 26, 2009 | 03:49 PM
cruznMel's Avatar
cruznMel
Default Small portable air compressor
Does anyone know of a good small portable air compressor that will not blow fuses as I've read that some do? I want this in case of a flat tire when out in the boonies?
Old Feb 26, 2009 | 03:55 PM
hotwheels57's Avatar
hotwheels57
The GM oem C5/Z06 compressor should work for you.
SLIME has one available at any AUTOZONE or CHECKER AUTO.
THE TIRE RACK also has one.
Keep in mind that the sealant "goop" from some sources may clog your tire pressure monitoring system sensors. But, if you're out in the boonies with a flat tire, that might be the last of your concerns.
I carry the GM oem sealant, but also carry tools for any occasion, including tire plugs.
By carrying tools with you all the time, you can almost guarantee that you'll never need them...
Old Feb 26, 2009 | 08:09 PM
dobewillie's Avatar
dobewillie
funny how that just seems to work
Old Feb 26, 2009 | 08:17 PM
Black04Z06's Avatar
Black04Z06
I have the same philosophy
I have the Z06 kit in the vette and a slime kit in my Silverado LTZ (has pressure sensors). I also carry the plug kit.
I also have a 12 volt light in my collections because this sh*t usually happens at night
Old Feb 26, 2009 | 08:28 PM
yaknow's Avatar
yaknow
perfectly stated
Old Mar 7, 2009 | 06:01 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
What is the cigarette lighter fuse rating for a c5 coupe?
Old Mar 7, 2009 | 08:44 PM
CRV3TT3's Avatar
CRV3TT3
I have this one for my track and off-road outings. Very nice piece for cheap!
Old Mar 7, 2009 | 09:24 PM
Grzldvt1's Avatar
Grzldvt1
I have a Campbell-Hausfield, I picked up at Home Depot, that has a light on it and have never blown a fuse. I have used it several times with no issue.
Old Mar 7, 2009 | 09:40 PM
O4-/-C5's Avatar
O4-/-C5
I carry a Victor Battery Jump Starter with a built in tire pump.
Kills two birds with one stone - I can start the car with a dead battery and pump up a flat tire after a fix.
Old Mar 7, 2009 | 09:56 PM
Hammer99's Avatar
Hammer99
I have the Slime kit...compressor, plugs, sealant in a nice carry case.The sealant does not harm the sensors...so they claim. 79.95
Old Mar 7, 2009 | 11:30 PM
BanditDude's Avatar
BanditDude
I have the ContiComfortKit from TireRack.
link
Old Mar 7, 2009 | 11:39 PM
army2000's Avatar
army2000
St. Jude Donor '11
Seriously, no need to go over board with it. I bought a $10 one from Walmart 5 years ago and it worked fine. I've used it several times to add air in my tires.
Old Mar 8, 2009 | 07:26 AM
DeeGee's Avatar
DeeGee
Me too. I picked up a combined car vacuum/compressor at Walmart for $10. Its been going strong for 5 years now
Old Mar 8, 2009 | 08:21 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 8, 2009 | 04:36 PM
borkg2006's Avatar
borkg2006
Got mine at Home Depot, SKU #401-711, cost about 20 bucks. Very small and works off the lighter/power outlet without blowing fuses.
To Small portable air compressor
