[Z06] Rear Tire Width
Old Mar 2, 2009 | 11:17 AM
Bronk's Avatar
Bronk
Default Rear Tire Width
What is the widest width rear tire replacement I can use without encountering problems, ie; rubbing, extreme extension outside the fender well opeinings? Thanks in advance for information.
Bronk
Old Apr 29, 2009 | 10:01 AM
HUSKER-Z's Avatar
HUSKER-Z
assuming for a C5Z? Stock rear rim? I've heard 305's....
Old Apr 29, 2009 | 10:07 AM
waktasz's Avatar
waktasz
315 is the widest I've done, but that's on race tires...you'd have a hard time cramming a 315 street tire on the wheel, but it does fit under the car.
Old Apr 29, 2009 | 10:28 AM
AU N EGL's Avatar
AU N EGL
18x305
315 would be too tight
335 will rub and stick out
Old Apr 29, 2009 | 11:41 AM
hector88's Avatar
hector88
i currently have 335's on mine. it did rub but i just removed the air bridge thing.... the one that allows air to get to the rear pads. i really love the look of a 335 on my z. when i had 315's it would only rub when the car would twist like when i would go in my drive way.
Old Apr 29, 2009 | 12:15 PM
speedyhawk101's Avatar
speedyhawk101
335's on a stock wheel??
lubranjo's Avatar
lubranjo
since my car has had 280 miles nothing but drag radials... 315/30s on stock rims NO RUBS
Old Apr 29, 2009 | 01:10 PM
vms4evr's Avatar
vms4evr
I run 335 on an 18x12 CCW wheel. They rub just a bit on the inner fender. They stick out quite a ways.
Old Apr 29, 2009 | 01:40 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
On a stock 10.5 rim? IMO, a 305 would be the widest.
Old Apr 29, 2009 | 02:46 PM
speedyhawk101
I was referring to HECTOR99. I sure hope he's not runnig 335's on a 10.5" wheel. It would look terrible.
FWIW I'm running Stock Z wheels widened to 12" with a mini tub and 335's. LOVE THE TRACTION!
Old Apr 29, 2009 | 03:06 PM
miami993c297's Avatar
miami993c297
Hi speedyhawk101,
Can you provide more info please on your modification?
I intend to stay 18" with the OEM ZO6 rear wheel widened to 12"...then minitub...
Is the diameter noticable smaller when mounted on the car???
Do you have pictures?
How is the process of widening?
What are the downside of this mod?
What tire are you running?
Thanks in advance
Christian
Old Apr 29, 2009 | 04:09 PM
TheDingo's Avatar
TheDingo
Nevermind.
Old Apr 29, 2009 | 04:17 PM
miami993c297
Originally Posted by TheDingo
You know there is a search button right? This is one of the most common questions on here along with "what is this worth" etc
Sir,
I have already a file pretty complete on the subject...and I share with the members here my experiences (ref e.g. my Threads).
Be sure that the search button is a "tool" I deeply recommend to every one new here around.
A file is never too much updated and all piece of information is precious to avoid mistakes.
I am sure you will contribute to educate me on this item and your knowledge about how to weld the aluminium barrels is welcome.
Christian
Old Apr 29, 2009 | 08:36 PM
hector88's Avatar
hector88
yup
Old Apr 29, 2009 | 09:04 PM
ZShot's Avatar
ZShot
Putting 335's on the stock rim offers no increased contact patch vs a 305.
Old Apr 29, 2009 | 10:26 PM
hector88's Avatar
hector88
but i really like the look
Old Apr 30, 2009 | 01:17 AM
JETZ's Avatar
JETZ
Post some back/side shots!
To Rear Tire Width
Old Apr 30, 2009 | 07:49 AM
speedyhawk101
Originally Posted by miami993c297
Hi speedyhawk101,
Thanks in advance
Christian
I'll send you a PM.
Old Apr 30, 2009 | 09:31 AM
JLayer's Avatar
JLayer
I'm running a 305 on a 11.5 width wheel and they just barely stick out past the fender. I haven't had any rubbing issues though. The tire is a Nitto INVO.
Old Apr 30, 2009 | 10:20 AM
Rickyh93's Avatar
Rickyh93
I have 315/30's and haven't noticed any rubbing issues and they don't stick out. These are on 18x10.5 z06 wheels
