Old Mar 25, 2015, 06:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Replace Shifter Light Bulb
Old Mar 9, 2009 | 09:00 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default Replace Shifter Light Bulb
How do I replace the shifter light bulb for a 2004 with auto transmission? What is the bulb number?
Old Mar 9, 2009 | 09:17 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Automatic transmission indicator
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Sylvania Lamp Replacement Chart
Someone else should chime in on the how-to.
Old Mar 9, 2009 | 09:59 AM
ljthe2nd's Avatar
ljthe2nd
I found this the other day. http://forums.corvetteforum.com/c5-t...ment-pics.html
Old Mar 9, 2009 | 10:05 AM
DeeGee's Avatar
DeeGee
Here you go:
Trans Floor Shift Control Indicator Lamp Replacement
Remove the console to give access to the shift boot using these instructions from the Vette Essentials Website:
http://www.vetteessentials.com/instr...t_install.html
• Remove the floor shift control (the ****!).
• Remove the floor shift control boot assembly.
• Remove the lamp socket.
• Remove the bulb from the lamp socket
• Install the bulb to the socket.
• Install the socket to the shift boot assembly.
Replace the console
Old Mar 9, 2009 | 10:52 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Thank You all for your help!
To Replace Shifter Light Bulb
