Convertible top Hatch problem
Old Mar 21, 2009 | 01:32 PM
NOLAVette's Avatar
NOLAVette
Default Convertible top Hatch problem
Does anyone else have to hold up the convertible top hatch with your shoulder while raising or lowering the top? It seems the lift struts on either side have lost their lifting power and need to be replaced. Where's a good place to get them and about how much do they cost?
Thanks,
NolaVette
Old Mar 21, 2009 | 01:48 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I'm starting to have this issue with my 2002 vert. I asked my dealer to see if it's covered by my GMPP warranty, then I won't have to worry about it, but yes, the strut is worn and needs to be replaced.
Old Mar 21, 2009 | 03:24 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
I think any auto parts store like pep boys,advance,autozone would have them and they will not be a lot of $
Old Mar 21, 2009 | 03:27 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I ordered my struts for the tonneau cover from Fichtner Chevrolet, they were about $18 a piece. In fact I just ordered new ones for the trunk and hood. They were a little more, but not much more.
Call Bob @ Fichtner - he'll fix you up and he's a great guy to talk to....real friendly and knowledgeable!
Old Mar 22, 2009 | 01:56 AM
ToplessBlonde's Avatar
ToplessBlonde
Thanks for posting this.
All this time I thought that was just the way it work.
okay...I'm Blonde!
Gonna call the dealer on Monday!
Old Mar 22, 2009 | 02:00 AM
CUlookin's Avatar
CUlookin
I have an 04 and have never had this problem, not looking forward to it if it does occur!
Old Mar 22, 2009 | 02:02 AM
JMc's Avatar
JMc
Mine gets as LOT of use. I'm not surprised that the struts are giving out after 75k mi.
Old Mar 22, 2009 | 02:13 AM
DeeGee's Avatar
DeeGee
Looks like an easy fit. Here's the procedure for you if you want to do it yourself. At $18 for the part from Bob I think I'd tackle that.
ToplessBlond; My wife's blond so I know not to make blond jokes
Document ID# 656600 2002 Chevrolet Corvette
Folding Top Stowage Compartment Lid Struts Replace
Removal Procedure
1. Open the folding top stowage compartment.
2. Remove the forward end of the strut from the hinge ball stud.
3. Close the folding top stowage compartment lid.
4. Open the rear stowage compartment lid.
5. Remove the strut from the rear ball stud.
Installation Procedure
1. Open the rear stowage compartment lid.
2. Position the rod end of the strut through the access hole between the quarter panel and the support.
3. Install the strut to the rear ball stud.
4. Close the rear stowage compartment.
5. Open the folding top stowage compartment.
6. Install the rod end of the strut to the front of the hinge.
7. Close the folding top stowage compartment.
Old Oct 24, 2010 | 06:39 PM
JMc's Avatar
JMc
Removal Procedure
Reviving a very old thread here, but I'm about to finally take care of this problem and order some replacement struts. Just two questions:
1. Is there just one strut that handles this task or are there two? I have a hard time telling from the illustration.
2. What tool, if any, is required to remove the strut(s) from the ball studs? Thanks!
Old Oct 24, 2010 | 07:52 PM
blacksedan87
Jeff - there is one strut on either side of the car.
Tools, once you see the new strut, all you'll need is a small flat screwdriver to pull the collar away to allow you to remove the old strut. The whole operation shouldn't take more than about 10 minutes.....easy peasy!
Old Oct 24, 2010 | 08:03 PM
JMc's Avatar
JMc
Awesome, thanks Randy. I just replaced the struts on my son's Scion tC rear hatch today and it couldn't have been easier. Same deal. Small screwdriver to pry loose a spring clip on each end holding the strut to the ball. Super easy. Glad to hear this is the same deal. My only concern is being able to see where the screwdriver needs to go under there! But you've set my mind at ease. Thanks again.
Old Oct 24, 2010 | 08:36 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Old Feb 23, 2011 | 06:21 PM
mtdoragary's Avatar
mtdoragary
From: eustis FL Saved and blessed; what else matter?
My 2000 has TWO struts, one on each side and they're hidden pretty well. I can access the front end of the strut, but not the rear end, even with the cover pulled off.
Old May 16, 2011 | 10:26 PM
KGA 99vert's Avatar
KGA 99vert
Removal Procedure
I love my Corvette, I love this site and I love the search button.
I needed to replace my 2 struts. I got some new ones but wasn't sure about how to go about replacing them. I came here, searched and found this thread. Had them pulled and replaced in 5 minutes or less.
To all the informative folks here...
Old May 17, 2011 | 10:42 AM
Half-Life's Avatar
Half-Life
Agreed. Had the same problem last year, found this thread and problem solved.
Old May 17, 2011 | 10:54 AM
Paul Wood's Avatar
Paul Wood
Make sure you protect the top while you are replacing the struts. It is really easy to damage the material if you are not mindful of screwdrivers, etc.
To Convertible top Hatch problem
