weird headlight problem
Old Mar 22, 2009 | 10:27 PM
1Redctoo's Avatar
1Redctoo
Default weird headlight problem
A friend of mine has a 97 vert with this unusual problem . She was driving it the other day and the headlights came on and raised on their own. Didnt think much of it until this morning . Sometime last night while the car was parked in the garage it must have done it again cause they were UP and the battery was drained !
Anyone have something like this happen to them ? Any advice for her ?
Old Mar 23, 2009 | 12:40 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
sounds like a short circuit. The most likely problem is a short in the headlight switch on the steering column. It's a common thing to happen especially on older cars.
Old Mar 23, 2009 | 12:44 AM
1Redctoo's Avatar
1Redctoo
Default headlight switch
Thanks, is this something that can be fixed by a shade tree mechanic like myself or is it gonna involve a trip to the dealer .
Old Mar 23, 2009 | 12:50 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I can't say for sure, I've never done this myself, nor have i seen any how-to threads on this subject.
Old Mar 23, 2009 | 01:04 AM
molten vett's Avatar
molten vett
Default Howto: multifunctional switch removal
http://forums.corvetteforum.com/c5-t...f-replace.html
Here ya go
Old Mar 23, 2009 | 01:26 AM
DeeGee's Avatar
DeeGee
Unusual symptoms but a common problem. Its probably the turn signal switch
The other possibility is the headlamp control module. There are a few failures reported here. The fact that its only one headlight thats opening may mean the problem lies there. The T/S switch sends a signal to both headlights but that signal splits to the individual lights in the module. Follow my logic?
It would also be worth checking the grounds and make sure they are clean and tight. The headlight ground is just behind the passenger side headlight on the frame.
Not sure if these diagrams will help you but you can see the components in the system that might affect the headlight
To weird headlight problem
