installing a short throw shifter
Old Mar 23, 2009 | 01:23 AM
c130dude2002's Avatar
c130dude2002
Default installing a short throw shifter
i found a write up a few months back on how to remove the stock shifter and all your interior parts in order to replace the c5 shifter, now i cant find it anywhere, can sombody help me out?
thanks
Old Mar 23, 2009 | 01:25 AM
inrealtime's Avatar
inrealtime
thanks
I have this one saved. Hopefully what you are looking for.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Mar 23, 2009 | 07:16 AM
Hammer99's Avatar
Hammer99
If you are installing a MGW, it comes w/instructional CD...very simple to follow. Tip: when removing the "demon key" from your stock ****, use a paint can opener to pry up on the corners. Instructions say to use a screwdriver...good luck w/that!
Old Mar 23, 2009 | 09:36 AM
red97vette's Avatar
red97vette
yeah, that demon key is a bitch!!!
Old Mar 23, 2009 | 09:44 AM
o2z51's Avatar
o2z51
wrap the leather **** w/ a rag, and use 2 flat screw drivers one on each side to pry it up, Its the only way it will come up, 1 screw driver wont work.
Old Mar 23, 2009 | 09:46 AM
B-Vette's Avatar
B-Vette
Great write by CF member!
Old Apr 21, 2009 | 12:45 PM
B-Vette's Avatar
B-Vette
Absolutely right, using the two flat blade screw drivers is a excellent tip. I also used LPS Penetrate fluid on the key make the removal easier.
Old Apr 21, 2009 | 01:49 PM
nextime's Avatar
nextime
Mine was easy!
Old Apr 21, 2009 | 03:42 PM
GreenDream's Avatar
GreenDream
WD-40 and paint can openner.. I tried every screw driver in the tool box until the idea hit me for the openner. It worked like a charm..
To installing a short throw shifter
