I'll try and find the link again since nobody here seems to want to help others do the legwork...
I'll post the link when I find it, but I think the guy had something like 332hp/336tq and went to 365hp/3xxtq. He had supporting bolt ons and already had a previous tune. So, all things being equal the gains were from the headers alone and just a modified tune when adding the headers.
Ok, so the HP increase rate is similar between the two graphs, that's good!
So you went from 325.79 hp & 336.68 Tq to 356 hp & 365.4 Tq, so you gained 30.21 Hp & 28.72 Tq from headers and a fresh tune, not bad considering it had already been tuned before! With the mods you have I would have expected more if it had never had a tune before, or less if it didnt have a tune and you didnt get one this time.
So that's not bad.
You have 350 torque from 2500 -5250 RPM with it peaking at 365.4, & still over 310 Tq down at 2000 RPM, that's pretty darn good I think!
Here is a link regarding installation and dyno results from this OBX header system. The dyno results are in post #91. The pictures of the dyno sheet are no longer available.
Just got it dyno tuned by Charlie at RPM. Before the headers I had the Vararam, Borla Cat Backs, 3.42's and a dyno tune with RWHP 326. Now with the OBX headers and great tune by Charlie I got 356 rwhp and 365 ft-lb of torque! I asked Charlie how these headers compared with others and he said they were slightly above average in the hp gain and that the torque was the really impressive thing. I will look for my old dyno sheet and let you know the peak torque back then. If i remember right the peak torque was less than 320 ft-lb. As for now here is a few pics of the dyno sheet. Hope this answers any ?'s if not let me know
Resonators are simply hollow tubes with maybe some sound baffling material inside. Cats are catalytic converters used for emissions control. Resonators have no emissions regulation, they will not pass inspection.
This is my understanding, someone correct me if wrong.
here in PA if resonators look like cats they should pass, its a visual check only. They seem to look the same to me. But would resonaters pass an emissions check if they actually start taking exaust readings? Are resonaters designed to filter unburnt fuel?
They are just hollow tubes with sound baffle material, and sometimes just plain hollow tubes. My B&B Bullets have resonators instead of mufflers. They are just a hollow tube with absolutely nothing on the inside. You will have to have a tuner omit the 02 readings from the system. If an Emissions Station only checks for codes or does a visual inspection you might be ok.
If they sniff the tailpipes, you're screwed.
Here is a photo of the inside of the "resonators" on the OBX setup:
Yeah I have the bullets too and the resonators have NO emmissions control. They are not deigned for it. But back on topic, the horsepower gains are spot on. Plus the ease of installation for the other guys seems to be just as easy as the big brands
The resonators are purely for sound. The inspector may or may not notice the fact that the resonators are not cats. You have a better shot of getting away with it if you install your 02 sensors and get a tune to disable them.
Are cats made in a "one-size fits all" or different sizes?
-Alex
There are universal or car specific. The universal will generally just have a size for the tubing. You would need to get a pair of catalytic converters that match the size of the exhaust tubing you are feeding in and out.
Never heard of them and they don't list flow numbers.
Random technologies lists their flow numbers and they claim they flow as well as, if not better than, a performance muffler. Random Technologies also uses stainless steel for the cats. Are the cheapies above stainless or are they going to rust out? How do the cheapies above connect into the exhaust system. Do you have to weld them in, clamp them in or do they bolt in?
I mean like length sizes. Are all cats the same length so you don't have to worry about cutting the exhause at all?
-Alex
Hard to say. I know the OEM cats and after market replacements for OEM are generally the same length and mount points as the stock locations.
Once you start talking headers, it is a different ball game. It depends on how the header manufacturer designed the headers. A lot of the bigger name designers seem to use Random technologies converters, so the headers are designed to mount up with either those or a mid-pipe and still connect to the factory cat back system. Think about the parts to the system. There is the header itself, the x-pipe + cats or some x-pipe + off-road pipe, then the factory cat back.
Other brands of converters may work if they are the same size. I would say you are SOL if its a universal catalytic converter.
Does anyone have links to any dyno results besides only the one I could find when I did a search here?
Once I get my cam installed, I'll have some dyno numbers for all you worry warts out there !
And 03vettemaniac is the member with nothing but great things to say about these headers. Not to mention all the proof that they are just as good as the HIGHER priced brands,
I'd like to see a setup with just the header system and the usual bolt ons.
