FRC Removal?
Old Apr 16, 2009 | 11:18 PM
Turbopower87's Avatar
Turbopower87
Default FRC Removal?
I am going to start painting some underhood stuff and plan to start with the fuel rail covers... how do I get the driver's side off without damaging anything?
Searching the forum as well as owners manual has produced nothing. I just don't want to do any damage before I even start painting them.
Old Apr 16, 2009 | 11:21 PM
happa's Avatar
happa
Take the oil cap off and pull they come right off Show us pics when your done
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
If it's stock you just pull it up just like the other side.
Old Apr 16, 2009 | 11:36 PM
jrose7004's Avatar
jrose7004
Pull up firmly from the bottom.
Old Apr 16, 2009 | 11:37 PM
Turbopower87
The driver's side has the fuel line going through it and it doesn't look like I could just slip the rail over it without disconnecting it. I have an 04 so only one line in the way.
Old Apr 17, 2009 | 12:44 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
It will come off. The FRC is sliced all the way down so you can pull the FRC right off the fuel line. Just go give it a few tugs and you will see how easy it is to get them off.
Old Apr 17, 2009 | 01:02 AM
bencini231's Avatar
bencini231
When I remove mine I always tape the edges where the fuel rail slides thru.
Old Apr 17, 2009 | 01:35 AM
SeanMounce's Avatar
SeanMounce
good idea.
Old Apr 17, 2009 | 01:39 AM
DeeGee's Avatar
DeeGee
Just bend the edges gently as you ease it past the oil lines.
Old Apr 17, 2009 | 07:40 AM
moserbe's Avatar
moserbe
It will come right off without damaging anything.
Old Apr 17, 2009 | 08:32 AM
CorvetteOJ's Avatar
CorvetteOJ
Originally Posted by SeanMounce
good idea.
Yes, this is the only way to remove them safely. I have removed mine a few times and each time I have put two layers of masking tape on each side. It is also a good idea to wrap the line with a thin layer of masking tape. This will smooth out the line tremendously. Mine are still perfect around the fuel line. Don't forget the most important thing...PATIENCE!!! good luck with your project.
OJ
Old Apr 17, 2009 | 09:39 AM
Turbopower87
Thanks a lot guys I'm hopefully going to start in on them this weekend. I'll have pics up in a week or so if I have time to finish them.
Old Apr 17, 2009 | 11:28 AM
bucwheat's Avatar
bucwheat
OJ
Good advice,I just did mine and they turned out great.
Old Apr 18, 2009 | 12:06 AM
That or put some tape over the fuel line itself. The cover is flexible so if you pull up on one side of the split, it will clear the braided line.
Old Apr 18, 2009 | 12:24 AM
dobewillie's Avatar
dobewillie
Old Apr 18, 2009 | 12:39 AM
tlc0706's Avatar
tlc0706
To each his own, I simply wrapped a small towel around the line....pulled up from the bottom and slightly twisted the FRC over the line...quick
Old Apr 18, 2009 | 08:29 PM
Turbopower87
Here's what I've done so far. I plan to paint the letters and stripes black and if they don't come out I'll just get the stickers to go over the paint.
To FRC Removal?
