Jump Start 2003
Old Apr 17, 2009 | 05:06 PM
kozmo's Avatar
kozmo
6th Gear
Default Jump Start 2003
Can I jump start with another car? Do I need to buy an electric(plug in) jump starter? I know is has a smaller battery and did not want to overcharge/overload? Thanks.
Old Apr 17, 2009 | 05:11 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Shouldn't be a problem jumping a C5 with another car. Even a foreign car will work, although not recommended.
Old Apr 17, 2009 | 05:53 PM
kozmo's Avatar
kozmo
6th Gear
Will the computer memory be gone? Will it stay charged or do I need to measure the battery before parking somewhere else? Will it fully recharge from a battery tender over a time period? Thanks.
Old Apr 17, 2009 | 06:13 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
You will have no problems. I've jumped mine a few times after I opened and closed my door too many times when doing mods. I don't know about the rest of the C5s, but mine is sensitive!
Old Apr 17, 2009 | 06:44 PM
Dave68's Avatar
Dave68
If your battery is too weak to start your car, then yes, before you take your car anywhere but home, you must fully charge the battery with a battery charger - NOT a battery tender. That is for maintaining a full charge, only. Driving your car when the battery is weak is not good because it forces your alternator to work overtime. Either buy an automatic battery charger or take your battery to an auto parts store to have them charge/check it.
Old Apr 17, 2009 | 07:28 PM
R Devil's Avatar
R Devil
I've jumped mine via my F-150. No issues.
Old Apr 17, 2009 | 07:29 PM
dobewillie's Avatar
dobewillie
good luck
Old Apr 17, 2009 | 11:49 PM
Yes, you can jump the C5 with another car. Shouldn't be a problem at all.
Old Apr 18, 2009 | 08:53 AM
kozmo's Avatar
kozmo
6th Gear
One more question. Once I jump it and if later in the day if it does start on it's own, is it safe to assume the battery is fully charged, or should I have it checked out, so as to not overwork the alternator? Thanks alot guys.
Old Apr 18, 2009 | 09:39 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I hope nobody was watching...... Ford jumping a Vette.
Old Apr 18, 2009 | 03:03 PM
kozmo's Avatar
kozmo
6th Gear
One more question. The manual tells me I need a negative ground system. Can I ground it to any other metal on the car or should I hook up the negative to some place special? Thanks.
Old Apr 18, 2009 | 04:17 PM
Dave68's Avatar
Dave68
No, this is no indication that the battery is fully charged. You should have it charged if you don't have a charger.
Regarding the correct sequence and negative connections, take a look at this:
http://www.carbuyingtips.com/jumpstart.htm
Scroll down to the pictures for views of correct cable clamp hookups.
To Jump Start 2003
