please help seat question
Old Apr 23, 2009 | 06:52 PM
kismybass's Avatar
kismybass
Default please help seat question
i had the standard seats in my 99 vert. I just installed sport seats from an 00. Everything works on the passenger side. The problem is the drivers side. the only thing that works right is to move the seat forward,when the switch is pushed backwards the back base goes up,when i push the switch to move the front of the seat down the seat moves backwards and down, when i push the switch to move the base rear down nothing happens, when the switch is pushed to move the base rear up it moves down. The car does not have telescope steering wheel option. what do i do with the blue plug on the seat . pleeeease help me
Old Apr 23, 2009 | 10:49 PM
kismybass's Avatar
kismybass
Please help me
Old Apr 24, 2009 | 08:03 AM
kismybass's Avatar
kismybass
Bump for the day im desperate
Old Apr 24, 2009 | 08:20 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Sounds like the harnesses are different. You may have to check each wire and customize one end of the plug so that the controls work the way you expect them to. It will be time consuming but probably not too difficult/
Old Apr 24, 2009 | 08:36 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Apr 24, 2009 | 08:46 AM
bucwheat's Avatar
bucwheat
If you still have the old seat see if the plug matches the new on,if not use the old plug and do a little reserch on what wire operates what and change the pins.
Old Apr 24, 2009 | 10:17 AM
97C5owner's Avatar
97C5owner
Leave the blue plug be brother. Its for the telescopic steering wheel (i believe you said you don't have it).
Old May 3, 2009 | 02:38 PM
jasmanjr's Avatar
jasmanjr
5th Gear
I am new to this forum and still learning the ropes. Just posted a similiar question. A trial test of the new seats gave me all the functions, even the lumbar, which the original seats did not have. I do not have the telescoping wheel, so I am good. I can now proceed with recovering the nicer seats without wondering, "What the heck is that blue plug for?" Thanks again for the tip.
Old May 3, 2009 | 02:52 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Welcome to the best place on earth to find out about your new Vette
Old May 4, 2009 | 03:18 AM
DeeGee's Avatar
DeeGee
with the guys. It sounds like you have a different connector.
Heres the wiring digram for the memory seats option which shows which wires go from the switches to the control module for each function
HTH
To please help seat question
