Help changing out water pump.
Old Apr 24, 2009 | 09:02 PM
rrod100's Avatar
rrod100
Default Help changing out water pump.
I wanted to change out the water pump this weekend and was wondering if someone had some detailed instructions. Not much of a mechanic however it doesn't look all to hard. Any advise would be appreciated
Thank you
Old Apr 24, 2009 | 09:36 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I know some will disagree, but it is quite the pain. hardest part is laying across your engine trying to work a tool..ouch! I had my dealer do it while I drank free coffee and was entertained by the cashier
Old Apr 24, 2009 | 10:15 PM
z06 hellcat's Avatar
z06 hellcat
try this link!
http://www.ls1howto.com/index.php?article=26
Old Apr 24, 2009 | 10:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
its about a 90 minute job without rushing....just make sure you have plenty of coolant on hand to do a proper drain and fill. I also recommend changing your belt if it has not been changed recently.
Old Apr 24, 2009 | 11:34 PM
chargedc5's Avatar
chargedc5
Just like all of the above people said, "leaning over the car and replace the belts because there is nothing worse than fixing the water pump and a month down the road have a squeeking belt....! Dont forget the ac belt
Old Apr 25, 2009 | 02:51 AM
DeeGee's Avatar
DeeGee
Here's the procedure from the book
PM me with your e mail if you want the full version with pics.
Document ID# 361646
1999 Chevrolet/Geo Corvette
________________________________________
Water Pump Replacement
Removal Procedure
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable.
2. Disconnect the intake air tempeture (IAT) sensor connector.
3. Disconnect the mass air flow (MAF) sensor connector.
4. Remove the air intake duct/cleaner assembly.
5. Remove the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical.
6. Drain the cooling system. Refer to Draining and Filling Cooling System .
7. Remove the radiator inlet and outlet hose clamps from the water pump.
8. Remove the radiator inlet and outlet hoses from the water pump.
9. Remove the heater hose clamps from the water pump.
10. Remove the heater hoses from the water pump.
11. Perform the following steps on vehicles equipped with a bolt on water pump pulley.
A. Remove the water pump pulley bolts.
B. Remove the water pump pulley.
Remove the six water pump retaining bolts from the engine block.
Remove the water pump.
Installation Procedure
1. Clean the water pump gasket surfaces.
2. Install new water pump gaskets with the tabs up.
3. Install the water pump to the engine block.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
4. Install the water pump bolts into the engine block.
Tighten
a. Tighten the water pump bolts to (first pass) 15 N•m (11 lb ft).
b. Tighten the water pump bolts to (final pass) 30 N•m (22 lb ft).
. Install the water pump pulley.
A. Install the water pump pulley bolts.
Tighten
a. Tighten the water pump pulley bolts a first pass evenly to 10 N•m (89 lb in).
b. Tighten the water pump pulley bolts a final pass to 25 N•m (18 lb ft).
Install the heater hoses to the water pump.
Install the heater hose clamps to the water pump.
Install the radiator inlet and outlet hoses to the water pump.
Install the radiator inlet and outlet radiator hose clamps to the water pump.
Fill the cooling system. Refer to Draining and Filling Cooling System .
Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical.
Install the air intake duct/cleaner assembly.
Connect the MAF sensor connector.
Connect the IAT sensor connector.
Connect the negative battery cable.
Tighten
Tighten the negative battery cable bolt to 15 N•m (11 lb ft).
Program the Transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
Start the engine.
Inspect the water pump for leaks.
To Help changing out water pump.
