***Python Stuck Inside Rear Speaker Panel***
Old Apr 27, 2009 | 08:44 AM
R Devil's Avatar
R Devil
Originally Posted by WKMCD
That title better not be a euphemism for something else.
That was my first thought too.
Old Apr 27, 2009 | 08:47 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
From: www.modular-concept.com www.flatoutimaging.com
Originally Posted by XtremeVette
lol I was was waiting for a comment like this....
hmmmm You might want to PM Andy Wheeler lol! He has a new found love for snakes.
Holy S you guys are NUTZ
Seriously good luck man sounds like Greg (YELLOHH) has the best experience here with your situation.
Andy
Old Apr 27, 2009 | 08:52 AM
Dominic Toretto's Avatar
Dominic Toretto
Originally Posted by YELLOHHH
The more parts you remove, the further she'll back up into a place where you can't get to her. Trying to yank her out when she is wrapped around stuff will only hurt her. I'd put a big bowl of water in the rear hatch and be very patient.
I've owned snakes for almost 20 years, and have helped remove dead ones from up under dash boards. It's not fun. I used to let my Ball Python hang from the rear view mirror so I could keep an eye on her. Later, a Burmese I had was just too big to be transported without being in a pet carrier. Same with my current Red Tail Boa. Get yourself a pet transporter, something usually used for cats or small dogs. It really is the responsible thing to do. Best of luck getting her out without hurting her.
Yeah that's why I don't want to pull the animal in fear of hurting it. I'm just "lucky" this happened while it is warm enough out now that it will not be in any danger of not being warm consistantly.. I was actually outside feeding it as we had some company and using the AC it was like 65 inside an didn't want it in the cold. So I had it in its usual feeding tub with the mouse and after it ate I just put it in the trunk with the hatch open while I was talking to someone outside as I didn't want it to get out of the tub and under the car. Instead this happens LOL.
-Alex
Benpup's Avatar
Benpup
Cruise-In VI Veteran
We have all heard of a Trunk Monkey, but this is just !
Old Apr 27, 2009 | 09:02 AM
Dominic Toretto
Now that's just funny.
-Alex
Old Apr 27, 2009 | 09:24 AM
Cod's Avatar
Cod
Bazinga!
St. Jude Donor '09
Like Yellohh said, try water and maybe even lay a heating pad in the same area, not too hot just warm enough that she'd want to come lay on it.
Other than that Good Luck!
Old Apr 27, 2009 | 09:27 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Apr 27, 2009 | 09:33 AM
FLATOUT's Avatar
FLATOUT
Temporary Hold
Originally Posted by Willfulone
Peace
Chip
:rof l:
HAHA All his friends on the Corvette Forum will miss the car LOL.
Old Apr 27, 2009 | 09:36 AM
Robls6's Avatar
Robls6
Now I have seen it all...
Old Apr 27, 2009 | 09:39 AM
Dominic Toretto
Peace
Chip
LOL at miss the car!!
-Alex
Old Apr 27, 2009 | 09:43 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
And here I thought every conceivable problem that could ever occur with these cars has already been posted.
I was wrong.
I like the mouse, lawn chair and beer idea. Good luck!
Old Apr 27, 2009 | 10:28 AM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
take it to the dfw meetup with the snake still in there.. it'll be a nice surprise for people checking out your car
Old Apr 27, 2009 | 10:53 AM
  #33
Turbopower87's Avatar
Turbopower87
This is by far the strangest thing I've ever seen on the forum.
Any way to put a mouse in a ventilated box so that the snake will still smell (?) him and the mouse won't be able to run all through the car? You might as well go all out with putting water, heating pad and mouse in there to try to flush him out of hiding.
How long is the snake?
Old Apr 27, 2009 | 11:00 AM
  #34
Dominic Toretto
Pics for reference.
Snake is a little over 3 feet in length.
-Alex
Old Apr 27, 2009 | 11:01 AM
  #35
7898VETTMAN's Avatar
7898VETTMAN
If I remember right I had to pull the top piece off where the roof latches at the rear followed by the side piece where the speaker is.I am a little sketchy on the order as I did it last summer to replace the seatbelt.I had also taken the seatbelt bolt out on the floor too but all these pieces were necessary to get the b-pillar trim out.Not much more than a screwdriver and an allen key were used.Pretty sure top side and seatbelt at floor were the order used.Hope this helps.
  #36
GreenDream's Avatar
GreenDream
Alex,
How about cranking up the bass full bore and vibrate him out of there..
I'm thinking Led Zeplin would do it..
Old Apr 27, 2009 | 11:18 AM
  #37
GEMcLean's Avatar
GEMcLean
Default From Shop Manual - Speaker Replacement - Rear (Coupe)
1. Open rear lift window panel.
2. Using two flat bladed tools, CAREFULLY and simultaneously pry at the upper RH and LH edges of the rear speaker grille to release the locking tabs.
3. Pivot the speakr grille downward to release the lower retaining tab, then remove te grille.
4. Remove the push-in fastener (inthe lower corner of the speaker opening) retaining the rear compartment side trim panel.
5. Remove the rear speaker retaining screws.
Finesse the rear compartment side trim panel carefully upward, rearward and outward slightly to access the upper speaker retaining screw.
6. Begin to remove the rear speaker in order to access the electrical/audio connector.
7. Disconnect the electrical/audio connector from the rear speaker.
8. Remove the rear speaker.
Good Luck!
To ***Python Stuck Inside Rear Speaker Panel***
Old Apr 27, 2009 | 11:41 AM
  #38
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Originally Posted by AlexSmith
I considered getting a mouse too but I do not have a partition to keep it from getting into the passenger area. I suppose I could toss one back there, grab a lawn chair and some beers and see what happens LOL.
-Alex
Put the mouse in a cage and the noise should get the snake to come out!! Good luck!
Old Apr 27, 2009 | 01:08 PM
  #39
rpm462's Avatar
rpm462
What about getting some of that Snake-away or maybe some moth-***** from Lowes or Home Depot? Put it by the speaker box and the odor should drive it out. Good luck!
Old Apr 27, 2009 | 01:12 PM
  #40
YELLOHHH's Avatar
YELLOHHH
Snakes don't have ears.
