Window Replacement
Old Apr 29, 2009 | 01:56 PM
mickey_7106's Avatar
mickey_7106
Default Window Replacement
some a$$ broke into my car this morning and took my ipod. has anyone done a window replacement? its on the driverside. i found a used one for $70 but ive read on some sites that i need new moldings?
Any info will be greatly appreciated
Old Apr 29, 2009 | 02:08 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Sorry to hear about the break in. No you don't have to replace the moldings unless they are damaged. Not that hard at one point when I had 2 C5's I swapped side windows so I could keep the tinted ones. Took me about 1hr each.
Good luck
Old Apr 29, 2009 | 03:49 PM
mickey_7106
Good luck
thanks.. anything i should avoid or be aware of?
Old Apr 29, 2009 | 05:06 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Nice to have a friend hold the window while you bolt it down.
Old Apr 29, 2009 | 05:09 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You don't need new molding as they are built into the roof and door channels.
You're just going to have to pull door panel and the maybe adjust the tilt in of window once it's installed.
There are tow plugs on the bottom of the door to adjuts the tilt in.
Sorry for your bad luck.
Old Apr 29, 2009 | 05:43 PM
mickey_7106
sweet! thanks a lot guys
Old Apr 29, 2009 | 10:34 PM
mickey_7106
got her all fixed up! i got a used window for $80 and it took me about 2 hours to put it on by myself..thank you all for your input
Old Apr 29, 2009 | 10:39 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Glad to here. Becareful out there in Oaktown
Old Apr 30, 2009 | 07:38 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Glad to see ya got it all taken care off.
To Window Replacement
