Driver Window Fix Question?
Old May 3, 2009 | 03:17 PM
RJMC5's Avatar
RJMC5
Default Driver Window Fix Question?
Hello all,
I am in the middle of replacing (if required) my window regulator and noticed that the cable closest to the mirror is not on the cute pink pulley, but is off to the side of the pulley between the door and pulley.
Could this be what is causing the window to bind when going back up?
Any help is much appreciated.
Rudy from NM
Old May 3, 2009 | 03:23 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have never had the door apart, But I would say try to put it where it belongs and try the window before you put it all back together.
Bill
Old May 3, 2009 | 03:29 PM
RJMC5's Avatar
RJMC5
Thanks, that is what I am thinking. Not much space to work with but it is worth a shot.
Old May 4, 2009 | 08:47 PM
JuicedH22's Avatar
JuicedH22
that is a common symptom when the window regulators fail (I found this thread because I was searching CF for a recommendation on where to find a cheap one). With hassle, you can get the cable back on the pulley, however it will shortly fail soon thereafter, you really need to replace the unit. If you are unsure, the unit consists of the slides on both sides, and the regulator motor in the center.
I will let you know if I find a deal, I know the dealer I went to today wanted $470, which is unheard of.
Old May 5, 2009 | 01:34 PM
JuicedH22's Avatar
JuicedH22
http://forums.corvetteforum.com/c5-p...tors-nice.html
best deal I have seen.
Old May 5, 2009 | 07:31 PM
TEXHAWK0's Avatar
TEXHAWK0
If the motor still works, you can also get them rebuilt at RegulatorUSA.
http://www.regulatorusa.com/
http://www.regulatorusa.com/product_...41&product=122
To Driver Window Fix Question?
