[Z06] Standing mile?
Old May 6, 2009 | 03:33 PM
Bertram65's Avatar
Bertram65
Thanks for the info, not sure if everyone realized I was asking about standing mile top speed, from a stop you run 1 mile, the speed I was interested in is the speed the car is at at the end of the mile.
Old May 6, 2009 | 03:35 PM
TheDingo's Avatar
TheDingo
After reading over the thread, it seems people are saying it is between 150 and 160
Old May 6, 2009 | 04:07 PM
Jaxian's Avatar
Jaxian
Default 155mph top speed? um..no.
I call major on 155mph area as top speed for these cars. My old 1987 C4 with a stock 240hp motor did 155mph in Motor Trend's top speed test issue. God knows I danced in the area of that number enough times before I started all the mods on the car to confirm it.
I find it incredibly hard to believe with 165 more horsepower and better aerodynamics than a C4, that a Z06 can only match the top speed of the older car. No matter how bad the gearing might be for top speed runs. It might not be the best gearing but its not that bad. I would have to dig through my old magazine tests but I recall them saying it was around 170mph which sounds a lot more feasable.
Considering that is still nearly 25-30mph slower than the C6Z (factory rated and backed up by owners at around 198mph) with only 100hp more and aero only .02 or so better I wouldn't hesitate to say even 170mph might be conservative by a few mph.
Old May 6, 2009 | 04:11 PM
TheDingo's Avatar
TheDingo
You're talking about top speed instead of a mile, right?
We're speaking C5Z speed at the mile.
The 2009 ZR1 runs the mile at 180mph. You can gauge your logic from that.
Old May 6, 2009 | 04:59 PM
Jaxian's Avatar
Jaxian
Default Top speed.
Yes, I was referring to top speed and not standing mile speed. Sorry if I was not clear about that.
Old May 6, 2009 | 05:19 PM
Drewstein's Avatar
Drewstein
A stock C5Z is gear limited to it's top speed of 170, not power limited.
Old May 6, 2009 | 05:47 PM
TheDingo's Avatar
TheDingo
^ in 5th gear?
Old May 6, 2009 | 05:58 PM
SCBQQSTN's Avatar
SCBQQSTN
^ yes
Old May 6, 2009 | 06:57 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Stock C5Z gear-to-gear speeds at 6500rpm
Stock rear tire: 295/35/18
Stock MN12 trans w/3.42 rear
_GEAR___RATIO____MPH__
1st Gear (2.97:1): 49.7mph
2nd Gear (2.07:1): 71.4mph
3rd Gear (1.43:1): 103.3mph
4th Gear (1.00:1): 147.7mph
5th Gear (0.84:1): 175.9mph
Source: http://xse.com/leres/bin/gearratio?t...le=35&wheel=18
Old May 6, 2009 | 08:17 PM
mulalleybs's Avatar
mulalleybs
Originally Posted by Drewstein
3.42 gears, regular t-56 trans gearing (5th =.74) and 345/30/19 tires.
My 4th pulls to 155mph which is just over my trap speed.
So i dont get it. We have the same gears, but you said you can go 220 mph in 5th?
Old May 6, 2009 | 08:34 PM
TheDingo's Avatar
TheDingo
According to him the 5th gear ratio is different, but i dont see 220 out of that either.. idk
Old May 6, 2009 | 10:33 PM
PhatZO6's Avatar
PhatZO6
I am close to stock.....Top speed check with a gps...177 on the speedo.....175 on HUD......174 on gps......5th gear....redlined...No more proof needed...............
Old May 7, 2009 | 02:05 AM
  #33
PRE-Z06's Avatar
PRE-Z06
He has taller tires too(345/30r19)...there has to be some tire expansion at over 200 also
Old May 7, 2009 | 12:45 PM
  #34
Drewstein's Avatar
Drewstein
My 5th gear is .74 compared to a Z .84, then I have taller tires with the 345/30/19s plus any expansion, and last I have a 6800rpm redline. Add it all up you can get to about 220mph in 5th.
Old May 7, 2009 | 12:58 PM
  #35
TheDingo's Avatar
TheDingo
So with my stock .84 gearing and i have the same rear tire (kind of) 305/30/19, and i can rev to 6700, what's my top speed going to be around in 5th?
Old May 7, 2009 | 02:55 PM
  #36
mulalleybs's Avatar
mulalleybs
Gotcha, im running 315/30/18 i think.. stock vettes are powerlimited for trying to go 200+ right? Well i wanted to go over 200 in my car but i got stock z gears *depressed* haha
Old May 7, 2009 | 03:25 PM
  #37
Pumba's Avatar
Pumba
My calculations come to a different top speed than the 220 mph that you stated:
1) Your 0.74:1 Fifth gear gives you 13.5% more speed than a 0.84:1 Fifth gear.
2) Your 345/30ZR19 tires are 3.5 percent taller than the stock 295/35ZR18 tires that come stock on a C5 Z06.
3) Your 6,800 rpm redline is 3.0% more than the 6,600 rpm redline on the stock LS6.
Those factors together 173 mph x 1.135 x 1.035 x 1.03 = 209 mph.
Oh yes, with my 0.563:1 Sixth gear, a 4.10:1 final drive ratio, and a 400 RWHP modifed LS6 engine, I have been at 192 mph.
(GPS verified).
To Standing mile?
Old May 7, 2009 | 03:40 PM
  #38
Mark W's Avatar
Mark W
So there are Two standing mile events that I know of LasVegas And texas. What I would like to know is Exactly when and where they are and what special eqyipment is needed?
Old May 7, 2009 | 04:09 PM
  #39
Drewstein's Avatar
Drewstein
According to the Calculator you should hit 181.8mph at 6700 in 5th minus any wheel expansion.
Old May 7, 2009 | 04:15 PM
  #40
Drewstein's Avatar
Drewstein
(GPS verified).
According to the Calculator I get the following
Gear Ratio MPH
5 .74 217
However I have only just crossed 200mph one time.
