newbie corvette question
Old May 14, 2009 | 07:07 PM
blackonblackZO6's Avatar
blackonblackZO6
Default newbie corvette question
The front spoiler on the c5s, how important is it to have it. I just see so many corvettes with them damaged and mine is starting to sag. Will it affect the way the car drives or handles if i remove it, or trim it back.
Old May 14, 2009 | 07:26 PM
dobewillie's Avatar
dobewillie
its needed to direct air to the motor
Old May 14, 2009 | 07:27 PM
WildTurkey's Avatar
WildTurkey
Old May 14, 2009 | 07:42 PM
ljthe2nd's Avatar
ljthe2nd
actually it helps direct the air across the radiator, to help cool the engine. Corvette's have used a front spoiler for this purpose all the way back to the C3's
Old May 14, 2009 | 07:49 PM
IMXCITD's Avatar
IMXCITD
you can pick up a new one and switch it out pretty easily.
Old May 14, 2009 | 07:52 PM
Dave Sweatt's Avatar
Dave Sweatt
It's a consumable, just like brake pads or tires. When it's too worn down replace it.
Old May 14, 2009 | 07:56 PM
TPA Z06's Avatar
TPA Z06
Definitely makes a difference. Dropped from about 228 - 230 degrees down to 212 after I installed the center piece that mine was missing.
Old May 14, 2009 | 08:18 PM
blackonblackZO6
thanks for the help.
Old May 14, 2009 | 08:24 PM
happa's Avatar
happa
You dont have to have the side ones. But its a must for the center one. Mine tore off onetime and my temp went way up without it
Old May 14, 2009 | 08:42 PM
blackonblackZO6
it is just the sides that are ripping off.
Old May 14, 2009 | 09:24 PM
c5blkvetteguy's Avatar
c5blkvetteguy
You can buy pieces to stifin-up the side parts. I have them and they are great. The side spoilers snug right up to the body. Mid-America sells them.
To newbie corvette question
