Blinker Relay
Old May 24, 2009 | 04:46 PM
Burn0ut's Avatar
Burn0ut
7th Gear
Default Blinker Relay
Hey guys,
I own a 2001 Conv. and I just started noticing that it has a problem with the blinkers.
I was on vacation the past couple days and in total since I bought it I havnt driven it much...yet
I was on the Highway today and I decided to switch lanes, flipped the blinker, nothing. Flipped it on again, no blinker. Hmmm thats odd.
I remember the old owner telling me about a problem like this and he said to press and depress the hazard flashers and it would be fixed so I did and abracadabra.
How do I fix this?
Old May 24, 2009 | 04:55 PM
ljthe2nd's Avatar
ljthe2nd
I sounds like you'll have to replace the flasher, which I think is built into the hazard switch. Or if you're looking for an easy way out (but it will only fix your turn siginals), you can install one of those bypass harnesses that they sell to cure hyper-flash caused by installing LED's in place of the stock incandescent bulbs.
Old May 24, 2009 | 09:13 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I have this saved in order to replace the flasher, one day...
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
Old May 25, 2009 | 02:38 AM
DeeGee's Avatar
DeeGee
with ljthe2nd that its your hazard switch thats on the blink - or NOT Those are good instructions from Stickman81
You can replace the switch as described or fit the bypass kit
http://www.corvette-enhancements.com/c5_flasher_fix.php
There's even a thread showing how to make a DIY bypass:
http://forums.corvetteforum.com/c5-t...with-leds.html
HTH
Old May 25, 2009 | 06:17 AM
RonJ's Avatar
RonJ
Another by-pass supplier: http://www.adaptiveperformance.com/hyper.htm
RonJ ...
Old May 25, 2009 | 06:39 AM
jdmvette's Avatar
jdmvette
Night Owl for life
bypass harness is the way to go.
Old May 25, 2009 | 08:28 AM
RSchleder's Avatar
RSchleder
Richards bi-pass cable
To Blinker Relay
