Tendered or not?
Old Jun 15, 2009 | 06:29 AM
jfattizzi's Avatar
jfattizzi
Default Tendered or not?
I just replaced the battery with a duralast gold from autozone.
I use the car about 1 per week on the weekends.
My question is, should I keep it connected to a battery tender?
Old Jun 15, 2009 | 07:27 AM
AU N EGL's Avatar
AU N EGL
Allways.
Old Jun 15, 2009 | 08:12 AM
silversport's Avatar
silversport
If you are truly using it once a week there should be no need to...I don't with m,y '01 but I do find sometimes that I get busy and then it's two weeks before I get to drive it...It won't hurt to use the Battery Tender and the battery will thank you...
Bill
Old Jun 15, 2009 | 08:28 AM
jfattizzi's Avatar
jfattizzi
I try to use it once per week. Plus it is new (to me) and I have been playing around with the car getting to know it. So I open the doors, check the settings, etc. Like a kid on Christmas morning!
Old Jun 15, 2009 | 08:50 AM
I always kept mine hooked to a battery tender. Never had any problems.
Old Jun 15, 2009 | 08:55 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Hook mine to a CTEK every week...
Old Jun 15, 2009 | 08:58 AM
poolboy's Avatar
poolboy
I would suggest a CTEK - it is a combination tender/charger. I used to use a tender, but I found that if I did not put it on for a while, then decided I needed it, it would not bring the battery up to full charge, it would just maintain it at its diminished charge. These cars are very sensitive to low voltage, and that would usually mean I would see Pull Key Wait 10 secs messages. Since I switched to the CTEK, no more messages. Talk to Chip at CCA - he can set you up with a CTEK.
Old Jun 15, 2009 | 09:05 AM
Zer0vette's Avatar
Zer0vette
Hmm, i've never used any type of battery tender on my vehicles, and i sometimes don't drive them for 2-3 weeks. What's the deal with these things? I've never had battery trouble... What's the benefit of them, other than keeping batteries charges for extended storage(months at a time)?
Old Jun 15, 2009 | 09:17 AM
Cod's Avatar
Cod
Bazinga!
St. Jude Donor '09
I use my C-Tek through the winter months but usually leave it off during the summer, the Vert is ok with 2 or even 3 weeks of not driving it..
Old Jun 15, 2009 | 09:19 AM
csexton's Avatar
csexton
Bills03Coupe's Avatar
Bills03Coupe
C5's are very electronics intensive, and will slowly drain the battery if the car sits more then a couple of weeks. The CTEK Multi3300, which I use, is a float charger. You can leave it on whenever you're not using the car, and it will maintain the battery at peak charge. It will never overcharge, even if left on indefinitely. A very worthwhile accessory for your Vette. Give Chip at CCA a call. He'll hook you up!
Old Jun 15, 2009 | 10:54 AM
jrose7004's Avatar
jrose7004
I use my car about the same amount as you do and I've never used a tender and have never had a problem.
Old Jun 15, 2009 | 10:58 AM
jfattizzi's Avatar
jfattizzi
That is good to know. Thanks jrose7004.
I already have a battery tender jr. for my Harley Davidson. The winter months it doesnt even get turned on! So it has dual purposes now, Harley in the winter, Corvette in the summer/winter
Old Jun 15, 2009 | 12:45 PM
GRUNIE's Avatar
GRUNIE
CTEK here
Old Jun 15, 2009 | 12:50 PM
killain's Avatar
killain
Oldtimer
Bill
If I'm not going to use my car for 10 days to two weeks, I put the battery butler on it. But If your using it once a week the alternator can handle that.
Old Jun 15, 2009 | 12:53 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
I use a battery tender myself, past 2 years with no problems.
I drive the car about 2 times a week.
Old Jun 15, 2009 | 01:07 PM
thisMSGgood4me's Avatar
thisMSGgood4me
You don't need a battery tender.
BTW LOVE the avatar!
To Tendered or not?
Old Jun 15, 2009 | 05:22 PM
wfdlt8's Avatar
wfdlt8
I have the same battery and have not had any problems with it. My car set several weeks this winter and was fine.
Old Jun 15, 2009 | 05:24 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
It certainly can't hurt it to connect it while you are not using the car... I only connect mine to the tender if it is going to sit more than 3 weeks. I've actlually let it sit 4 weeks once and it started right up(summer time of course). I have the Excide Orbtial battery.
Old Jun 15, 2009 | 05:52 PM
02 C5man's Avatar
02 C5man
I use a Priority Start. It just kills the battery whenever it gets too low. The only pain is that I have to reset the clock if it disconnects the battery.
