Headlight and elecrical problems
Old Jun 25, 2009 | 11:04 PM
acat1234's Avatar
acat1234
Default Headlight and elecrical problems
Left my 2001 coupe in winter storage until May 2009. Battery was shot even though on a trickle charger all winter. Replaced battery and all seemed OK until tonight. Left headlights on for over two hours and ran battery down. Let car sit for around 20 minutes and it started. However, the "Check Engine Soon" light came on and the headlights did not work. Got home OK, shut her down and restarted OK, hoever CES light still on and headlights do not work.
Any ideas??
Thanks in Advance.
Old Jun 26, 2009 | 01:20 AM
DeeGee's Avatar
DeeGee
Did you blow a fuse?
Try #6 in the footwell.
If not its a new battery I'd say. With running it down like that the battery may be dead particularly if its an AGM. If it is, you will probably have a bunch of U codes on the DIC
Old Jun 26, 2009 | 01:59 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
I hope you meant you had a Battery Tender on it and NOT a trickle charger...A trickle charger will FRY a battery if left on it for an extended period of time, and can cause other electrical problems....
Old Jun 26, 2009 | 10:39 AM
acat1234's Avatar
acat1234
I removed Fuse #6 in footwell. It was OK. Put it back in, started car up and, amazingly, headlights came on just fine and the CES light was off. Go figure!! Perhaps a power surge when the car started last evening caused a breaker to trip which reset itself last night. Don't know - just grateful!
As far as the charger I use during the winter, it is an automatic charger which I set at the 2 amp setting - is this OK or is a Battery Tender something different.
Thanks so much for the info.
Old Jun 26, 2009 | 10:57 AM
DeeGee's Avatar
DeeGee
WRT to your problem, there are no breakers as such. Your problem is almost certainly associated with the state of your battery. You've given it quite a hammering from what you describe. It would be worth having a free on load check at Autozone to see what shape its in.
WRT to the charger, a trickle charger is designed to recharge a battery overnight. A Battery tender is designed to give a very low rate of charge and is optimized to allow permanent hookup. They are quite different so its important to use the correct type.
Old Jun 26, 2009 | 11:07 AM
poolboy's Avatar
poolboy
What type of battery are you using? If it is an AGM type, then the trickle chargers we used to use for lead/acid type batteries is not the type to use. I have an Optima (AGM) and am very happy with my CTEK charger (talk to Chip at CCA) - it can handle the various types of batteries with ease, and if the battery needs a charge, it'll deliver one, but if it just needs to be maintained, it'll do that too.
Old Jun 26, 2009 | 11:22 AM
acat1234's Avatar
acat1234
Thanks for the replies. I have a regular lead/acid battery. Too cheap to spring for the AGM or Optima bateries. I have been using a Sears Automatic charger to maintain the battery during the winter. I set it at the lowest seting and it cycles as the batery charge goes up/down. I also have a Schumacher charger which goes into a "float" mode when the battery is fully charged. Do I need to get another type of battery mainteiner for the winter? Sorry to be so poorly informed but, as you can obviously trell, not real mechanically inclined.
Thanks Again.
Old Jun 26, 2009 | 11:40 AM
poolboy's Avatar
poolboy
Thanks Again.
Although I am not an expert, and did not stay at a Holiday Inn Express last night, it sounds like you should be OK with the chargers you have. The one thing I will point out is that the battery tray is right above a bunch of vacuum hoses and electrical connectors - most people go with AGM type batteries as they do not leak as much as lead/adid types - if you have a leak it can be very expensive to repair in a C5.
Old Jun 26, 2009 | 02:16 PM
acat1234's Avatar
acat1234
Thanks for the info. Will have to look into an Optima or AGM. Is either one better than the other? What type of life expectancy? Seems like my C5 goes through a battery in less than 24 months.
To Headlight and elecrical problems
