How many flat tires
Old Jun 30, 2009 | 05:33 PM
lil vette's Avatar
lil vette
Default How many flat tires
With some people worrying so much about getting a flat without runcraps.
How many flat tires have you had in your lifetime in any corvette.
I have had only 2.
Old Jun 30, 2009 | 05:35 PM
jrose7004's Avatar
jrose7004
I've had 2 and both were with runflats.
Old Jun 30, 2009 | 05:36 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
jinx
Old Jun 30, 2009 | 06:43 PM
Old Rotor Head's Avatar
Old Rotor Head
Just 1 in 130k miles running Nittos. A 1/2-13 x 4" bolt picked up on the hwy. Held air until I got home.
Old Jun 30, 2009 | 06:50 PM
ieatyllwcryns's Avatar
ieatyllwcryns
zero
Old Jun 30, 2009 | 06:51 PM
TEXHAWK0's Avatar
TEXHAWK0
I got two nails in the same tire within a month, but have not had another flat in over 5 years. Both were repairable, and both did not go flat. I found them in the garage before they went completely flat.
One was a double headed nail like they use to frame concrete forms that went in head first, and I still made it home. I started to pull out what looked like a metal pin, but it would not come out. Once we had the tire off the wheel, we found that it would not pull out because the head was inside.
Old Jun 30, 2009 | 07:14 PM
dobewillie's Avatar
dobewillie
just one
Old Jun 30, 2009 | 07:20 PM
Hammer99's Avatar
Hammer99
ZERO. Ya, I'm knocking on wood.
Oldvetter's Avatar
Oldvetter
I've had 3 flats with my 1998 C5 (120,000 miles). I use Goodyear OEM runflats.
Old Jun 30, 2009 | 09:48 PM
ecoman's Avatar
ecoman
None (Kock on wood)
Old Jun 30, 2009 | 09:49 PM
Redhawg's Avatar
Redhawg
Two and I hope no more
Old Jun 30, 2009 | 10:47 PM
countylawdog's Avatar
countylawdog
Had my 1st one this past Sunday ... 116 miles from home. Filled tire to 45 #'s and headed home ..... stopped twice to refill tire .... got it home w/ no further problem .... figured I got 6 miles to the # of air!
Old Jul 1, 2009 | 12:58 AM
I had one on my '99, and two on my '00. Runflats sure came in handy those times.
Old Jul 1, 2009 | 12:59 AM
DeeGee's Avatar
DeeGee
I've had a mix:
A nail through the tire. It caught the sidewall and the tire was toast. Luckily it was downtown Vegas.
A broken valve stem which was my own fault. I topped off the air and broke the stem pulling the air hose off. It left me about 5 miles from home so I needed the runflat to get me home.
I now have a leaky air valve. I need to replace the TPS I suspect its the O Ring. It's not likely to strand me but its just a PITA having to top it off every now and then.
Old Jul 1, 2009 | 02:53 AM
Choreo's Avatar
Choreo
None on any of my Corvettes up until 1986
C4 (non-RFs)
Over 70 nails total in all 4 tires in one day - box of nails apparently fell off a truck on the highway - I just thought I hit water - never lost any air - saw all the nails 2 days later! None of the tires repairable. All replaced by insurance less deductible.
2001 C5
1st set of GYRFs - no flats
2nd set of GYRFs - 3 nails one tire at different times 2 nails in another tire at different times - all repairable.
3rd set Michelin A/S ZPs - 2 flats on different tires at different times - both, metal objects in side walls - not rpairable - replaced by Michelin for free under 2-year replacement warranty.
Old Jul 1, 2009 | 03:02 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
2 flats and 1 blow out (broken bead at + high way speed, install screw up) with run flats and handled great.
Old Jul 1, 2009 | 09:35 AM
Dave68's Avatar
Dave68
I have had only 2.
I've had exactly 1 and I've owned Corvettes since 1979.
To How many flat tires
Old Jul 1, 2009 | 09:39 AM
nickolbag's Avatar
nickolbag
Had 2 at the same time when I must have hit something at night on the highway. Not fun. Then I had another on the highway when a new Michelin decided to blow out on me. Thank God for AAA!
Old Jul 1, 2009 | 10:10 AM
wcsinx's Avatar
wcsinx
I've had plenty. I lost count, but I have a special souvenir drawer in my nail/screw case for things I've pulled out of tires. Though all my cars have an air compressor and plug kit in the trunk, and I've never had a flat I couldn't fix myself.
Old Jul 1, 2009 | 10:20 AM
jovette's Avatar
jovette
One in 23,000 miles
