Please decipher this code
Old Jul 3, 2009 | 05:00 PM
Adoggy Phizzle's Avatar
Adoggy Phizzle
Default Please decipher this code
I got a History code B2605 in the SCM module. I pulled out my handy vehicle codes list for the DIC which I downloaded and printed from this great forum. What does seat front vert. position sensor failure mean and what might cause the code? It hasn't obviously happened again as it wasn't current "C", but what gives. Thanks for your help.
Old Jul 3, 2009 | 05:12 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would say it means just what it says, The sensor that senses the vertical position had a glich.
Old Jul 3, 2009 | 05:17 PM
Adoggy Phizzle
so, if it doesn't happen again, don't sweat it? Or lose some weight off my fat ****!
Old Jul 3, 2009 | 05:18 PM
Mr.Bill's Avatar
Mr.Bill
I never worry about history codes, For some reason the C5 is known for throwing random codes.
Just clear it and see if it comes back.
Old Jul 3, 2009 | 05:19 PM
Adoggy Phizzle
Thank you Bill and I bid you good day! Happy USA weekend.
Old Jul 4, 2009 | 02:31 AM
DeeGee's Avatar
DeeGee
This is the info from the book. As you can see, a small voltage variation will pop the code. The car certainly does throw random codes and all sorts of gremlins occur with dead or failing batteries. In this case it could be sensor related but I'm guessing. If it doesn't reoccur once you clear it I wouldn't lose any sleep.
DTC B2605 Seat Front Vert. Position Sensor Failure
Circuit Description
The memory seat functions, are operated when voltages from the LH seat switch are first applied to the LH Seat Control Module (SCM). The SCM then stores the voltage appearing at the front vertical position sensor signal wire when either memory push button is pressed.
The SCM provides a steady 5 volt supply (CKT 1985) and a ground (CKT 782) to the front vertical position sensor. The front vertical position sensor, which is a variable resistor, provides a return voltage on the signal wire (CKT 557) to the SCM. Depending upon the location of the seat motor, the voltage in the signal wire varies from .1 to 4.78 volts. When one of the memory buttons is pressed, the SCM applies voltage to the motor until the position sensor voltage equals the stored value. The seat will then have returned to the stored vertical position.
Conditions for Setting the DTC
The front vertical position sensor input, to the SCM, is under the voltage range of .1 V or over 4.78 V for 2 seconds or more.
Action Taken When the DTC Sets
* Stores a history DTC B2605 in the SCM memory.
* This DTC can only be set as a history code even if the malfunction is current.
* No driver warning message will be displayed for this DTC.
* The memory operation/function of the faulted position sensor is disabled.
Conditions for Clearing the DTC
* The front vertical position sensor input, to the SCM, is within the voltage range of .1 V - 4.78 V for 2 seconds or more.
* Using the DTC clearing feature in the IPC.
* Using a scan tool.
Diagnostic Aids
* If the DTC does not reset after the code is cleared, then the problem may be intermittent. Perform the tests shown while moving related wiring and connectors. This can often cause the malfunction to occur. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
* The following conditions may also cause an intermittent malfunction:
o There is an intermittent open, short to ground or battery in CKTs 557 or 1985.
o There is an intermittent open or short to battery in CKT 782.
o The front vertical position sensor is open or shorted internally.
* If the SCM is unable to determine the correct vertical position, manual power seat functions will still operate, but the SCM will not be able to recall the correct seat memory settings.
* Using a scan tool, select SCM data display and monitor the front vertical position data. Move the power seat vertically in both directions while monitoring the position sensor data. The voltage range should vary and stay between .1-4.78 volts depending on the position of the seat. This checks if the seat front vertical position sensor is open or shorted in different positions.
Test Description
The numbers below refer to the step numbers on the diagnostic table:
2.
This test checks if a DTC B2605 stored in the SCM memory.
3.
This test checks the LH seat front vertical position sensor voltage using a scan tool. Normal position sensor voltage range is between 0.1-4.78 volts.
4.
This test checks if the SCM is sending the correct supply voltage to the position sensor. The supply voltage measured must be between 4.0-5.5 volts.
5.
This test checks for an open or short to voltage in CKT 782 or in the SCM internal ground circuit.
6.
This test checks the output voltage level at the position sensor signal circuit. The signal voltage measured must be between 3.5-5.5 volts.
To Please decipher this code
