Front emblem lifting
Old Jul 4, 2009 | 02:50 AM
El original's Avatar
El original
Default Front emblem lifting
Anyone have any ideals how to refasten bottom end of front emblem, it is lifting and I dont know what to bond it with as the emblem at that point is very narrow? Am thinking about just replacing it but any suggestions appreciated...and saves me $70- (tried silicone..no go)
Old Jul 4, 2009 | 02:59 AM
DeeGee's Avatar
DeeGee
My suggestion would be to remove it and replace the 3M double sided tape. There are two pins on the front emblem to keep it in place so go easy.
Old Jul 4, 2009 | 03:49 AM
Shylor's Avatar
Shylor
3M double sided tape is made just for this.
Old Jul 4, 2009 | 08:41 AM
killain's Avatar
killain
Oldtimer
I think, if I'm not wrong, a '"Automotive grade" made of two-face tape which is more weather resitant. Just scrape it clean, wipe it off with a little brake cleaner and let dry and put on the two face tape and use an x-acto knife to cut away the excess and reinstall. Good luck. Nice simple job.
Old Jul 4, 2009 | 08:31 PM
Shylor's Avatar
Shylor
I'd use WD40 instead.
Old Jul 4, 2009 | 08:39 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Or use the correct product by 3M...adhesive remover.
Old Jul 4, 2009 | 10:23 PM
silverbullit99's Avatar
silverbullit99
Remove and replace it.
Old Jul 4, 2009 | 11:43 PM
ljthe2nd's Avatar
ljthe2nd
As the others here have suggested you should remove the emblem, remove the adhesive from the emblem, apply new 3M double sided tape and reinstall. Here a pic of the correct 3M tape to use. You can buy a whole roll or just a few pieces on ebay.
Old Jul 5, 2009 | 09:29 AM
Just take your time and carefully cut the new tape to match the emblem.
Old Jul 5, 2009 | 10:17 AM
killain's Avatar
killain
Oldtimer
Yeah your right, WD-40 and soap and water would be much safer. The brake cleaner might cause the thin plastic of the emblem to crack or melt. Your right, much better choice.
Old Jul 5, 2009 | 10:59 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Is this tape available at auto supply stores?
Old Jul 8, 2009 | 10:57 PM
El original
Thanks guys I will try the two sided tape...It just happens I ordered a blackout kit and it comes with two sided tape some of which I hope can be salvaged for such a small project...Greetings Rob
Old Jul 9, 2009 | 02:09 AM
Shylor's Avatar
Shylor
I got mine at a NAPA auto parts store.
Old Jul 9, 2009 | 01:52 PM
$$$frumnuttin'
just be sure to get the thin version of the tape, not the thick, which will make the emblem stand out from the hood, and look chitty
Old Jul 9, 2009 | 04:05 PM
jedblanks's Avatar
jedblanks
This happened to mine, but no amount of 3m or other automotive tape would hold it. It was warped either form the sun or too many encounters with a towel dry.
My solution was a high polish c5 emblem from e-bay, though I don't see any listed today.
Old Jul 10, 2009 | 08:01 PM
Shylor's Avatar
Shylor
This is interesting because the 3m tape is the same stuff GM uses. I am thinking maybe you didn't properly clean the surface of your paint for it to stick correctly.
Old Jul 10, 2009 | 09:46 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
this stuff
it's exactly what GM uses. both surfaces have to be absolutely clean, free from ALL silicone products
this one?
ambakershut is the eBay seller but I see they have none listed right now
Old Jul 11, 2009 | 06:24 AM
dieseldave56's Avatar
dieseldave56
Default R&R the emblem
Easy to to; Remove the emblem with waxed dental floss and 3M adhesive remover to clean car surface ( soak a shop rag and apply).
Clean the emblem of old adhesive Use 3M acrylic foam Plus double sided tape .015 thick ( not .03 or .045 as it will show). Apply the 3M Tape and trim to fit .
Now prep the car's painted surface . ( I used a light pencil to outline the emblem in place) Apply 3M Adhesion Promoter #06396 ( one packet runs about $2 from auto paint paint store) to the outlined area. Heat the two surfaces to 90 degrees and then . I apply pressure for a few minutes.
To Front emblem lifting
