Your DIC setting
Old Jul 9, 2009 | 12:01 AM
  #41
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Originally Posted by C5XTASY
Coolant temp primarily, switching to oil and transmission temps periodically, and with increasing frequency if the coolant temp begins to rise.
Ed
Same thing here.
Old Jul 9, 2009 | 12:25 AM
  #42
slvr76's Avatar
slvr76
Oil temp.
Old Jul 9, 2009 | 01:55 AM
  #43
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default Ebcm failed
I leave mine on "Service Vehicle Soon" and "Service Traction System"
Otherwise I leave it blank.
Old Jul 9, 2009 | 10:19 AM
  #44
ksvette74's Avatar
ksvette74
get in car, hit reset to get of the service tire monitor system. After that I tend to change every few weeks. I like the mpg stuff and also the tranny temp.
Old Jul 9, 2009 | 02:04 PM
  #45
kerryt1's Avatar
kerryt1
Oil Temperature, mixed with Coolant Temp.
Old Jul 9, 2009 | 04:02 PM
  #46
jedblanks's Avatar
jedblanks
At startup, I check battery volts, tire pressure and then watch oil temp until it's 150+. Then I watch oil pressure and switch between fuel mileage, range, and oil psi while driving.
I will also often pull codes to see if any are showing.
Old Jul 9, 2009 | 04:05 PM
  #47
blazer427X3's Avatar
blazer427X3
Blank most of the time occasionally Oil Temp and Average MPG when on a road trip.
Old Jul 9, 2009 | 04:19 PM
  #48
C5 4 ME's Avatar
C5 4 ME
Originally Posted by rpm462
Coolant temp here.
Old Jul 9, 2009 | 06:35 PM
  #49
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
MPG Average usually. I wish there was a way to set it to automatically cycle between all the readings.
Old Jul 9, 2009 | 08:33 PM
  #50
clif's Avatar
clif
St. Jude Donor '09-'10
I used to watch my MPG all the time. Now, it makes me sad to look.... My car drinks gas so fast now!
Old Jul 9, 2009 | 08:51 PM
  #51
Superman09's Avatar
0Superman09
Former Vendor
Instant MPG usually. When I'm get under 1/8th tank I switch to range. Usually flip through all however on a drive!
Old Jul 10, 2009 | 01:31 PM
  #52
j84buick's Avatar
j84buick
Oil temp here too.... but I usually scan through once during a drive.
Old Jul 10, 2009 | 03:31 PM
  #53
GK's Avatar
GK
AVG MPG on the DIC and temperature on the HUD.
I reset all the MPG related options after every refill.
Old Jul 10, 2009 | 03:42 PM
  #54
angman5's Avatar
angman5
I keep mine set on Large
Old Jul 10, 2009 | 05:15 PM
  #55
IM28702's Avatar
IM28702
Originally Posted by redrckt97
I leave it on oil temp most of the time - no regular guage for that.
+1
Old Jul 10, 2009 | 06:34 PM
  #56
Adrian-S's Avatar
Adrian-S
Front tire pressure. Once or twice during a drive I'll usually hit once to check rear, then 5 or 6 hits back to front.
Had enough nails in other vehicle tires to keep an eye out.
Also, when filling up, I set the pump on auto and walk-around glancing at the tires for anything stuck in them.
Paranoid? Maybe, but I can say thus far, I've always caught an object in the tire before it was too late.
-adrian
