overheating.......
Old Jul 9, 2009 | 12:20 AM
justin_heat05's Avatar
justin_heat05
Default overheating.......
Replaced the thermostat, burped the radiator, and checked the fans and still my engine coolant seems to be running too hot. Whats the next thing to check or do?
Old Jul 9, 2009 | 12:25 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
What is hot?
We need more info.
Check your air intake in front of the raditor
Old Jul 9, 2009 | 12:28 AM
DeeGee's Avatar
DeeGee
Bill beat me to it but look up into the radiator. The Vette takes air from under the car using the center deflector dam. Make sure no one took that off for starters. Give the radiator intake a good clean out getting rid of any debris.
The cooling fans don't kick in until 230 degrees and I'd see those temperatures regularly in Summer in Vegas.
Old Jul 13, 2009 | 10:14 PM
justin_heat05
it has a brand new radiator. Would replacing the thermostat with a lower degree help? I replaced it with a 186 degree. It only starts to run hot at about 70mph. It reach almost 240 at one time. Cruising around, it never gets too hot.
Old Jul 13, 2009 | 10:26 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Water pump?
Old Jul 13, 2009 | 10:31 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Is the 186(?) the OEM t-stat, does he need to tune the fans to that new t-stat?
Old Jul 13, 2009 | 10:36 PM
justin_heat05
oem t-stat
Old Jul 13, 2009 | 11:26 PM
justin_heat05
how much is a tuner?
Old Jul 13, 2009 | 11:38 PM
urfubar's Avatar
urfubar
200-300 for a good one...I know a good one if you are in NC.
Old Jul 13, 2009 | 11:51 PM
justin_heat05
ky, and almost broke.......lol I'm a young gun and new to the LS1 vette engine. Can a dealership do a tune? Where I live, there's not much knowledge in regular shops about newer models. The ones that do know and have the experience, usually work in the dealerships. How much do they usually charge?
Old Jul 14, 2009 | 12:14 AM
intoc6s's Avatar
intoc6s
Do the electric fan "modification" to manually turn on your fans. I saw it in a few places including "Ranger" s website.(a forum member that s an excellent driver). Maybe someone else ll give u a link to this...-Jason
Old Oct 27, 2009 | 05:49 PM
warlock007's Avatar
warlock007
first try what was said to others, i replaced the harmonic balancer and starting getting temps around 230 when sitting still and 200-220 when driving high way. i put the car up on lift and holy moly the amount of grass and pebbles in the condenser and radiator cooling vents. it took me an hour to air gun and water pressure to clean it out. dropped the temp 25 degrees stayed under 200 still and driving.
Old Oct 27, 2009 | 06:56 PM
Chicago1's Avatar
Chicago1
taken from another thread
230-240 F doesn't seem that high, check this out:
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
When you have "cooling problems" always check the radiator for foreign material (grass, leaves, plastic bags, etc.), since these C5s are bottom breathers, they act as road vacuum cleaners.
Be careful, with a leak, if air gets in the radiator, Dexcool turns to a muddy, thick brown and can foul up the cooling system.
Old Oct 27, 2009 | 08:45 PM
Bill W's Avatar
Bill W
Suggestion, after the engine is hot, shoot it with a heat gun just to make sure what the gauge is telling you is correct.
Old Oct 30, 2009 | 04:03 PM
warlock007's Avatar
warlock007
Not sure what the book says as I don't have one but I can tell you mine is stock. Thermostat opens about 180 low speed comes on just after don't see the hight speed come on unless AC is on. Also how it works on my 300C. In any case car runs at 194 after the cleaning compaired to 220-230 and never hits 220 in traffic anymore
Old Oct 30, 2009 | 04:11 PM
SaberD's Avatar
SaberD
yeah there is probably like a dead cat or something under your radiator shroud. fall can be really bad with the leaves too.
To overheating.......
