door external key lock
Old Jul 12, 2009 | 04:46 PM
newnum's Avatar
newnum
7th Gear
Default door external key lock
C5 2001
when I insert the key into the exterior door lock nothing happens.
key spins freely and it feels like nothing is being engaged.
Old Jul 12, 2009 | 05:33 PM
Trpblk04's Avatar
Trpblk04
Most likely a bad cylinder. Funny, i do notthink I have ever put the key in my door lock always use the remote!
Old Jul 12, 2009 | 06:13 PM
newnum's Avatar
newnum
7th Gear
Thanks a lot for your rapid response to my question.
Same as you, I never used the key door lock either until last month. I was getting ready to take a 7,000 mile road trip and I tried the lock before the trip because I was concerned about locking my only remote in the ignition.
What I decided to do was detach the remote from my ignition key and carry the remote in my pocket in case I left the key in the ignition and locked the door.
I am also experiencing a problem with my passenger window not operating. I have always had this problem but I found that if I slammed the door while holding down the power window button it would free up and work ok. After not driving the Vette for a couple of weeks or so I would still have this problem. Now the window will not go up or down but I do hear the relay clicking in the door when I push any of the power window buttons.
I have read some replys to this problem and some say it may be a bare wire shorting out in the harness connection between the body and the door. I will look into this tomorrow.
Again, thanks a lot for your response.
To door external key lock
